November 11, 2023 at 8:55 am
lim hyun
C:\Users\ST03\Desktop\file>"C:\Program Files\LS-DYNA Suite R13 Student\lsdyna\ls-dyna_smp_d_R13.1.1_27-g8731a0d8c5_winx64_ifort190.exe" i=C:\Users\ST03\Desktop\file\project.proj ncpu=2 memory=20m
License option : check ansys licenses only
* ANSYS 2023 R1 LEGAL NOTICES *
* Copyright 1971-2023 ANSYS, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited. *
* Ansys is a registered trademark of ANSYS, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
* documentation CD or online help for the complete Legal *
* Notice. *
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* ANSYS, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement. *
* ANSYS, Inc. is a UL registered *
* ISO 9001:2015 company. *
* This product is subject to U.S. laws governing export and *
* re-export. *
* For U.S. Government users, except as specifically granted *
* by the ANSYS, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the ANSYS, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses). *
***************************************************************Date: 11/11/2023 Time: 17:17:41
___________________________________________________
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Date : 07/28/2023 Time: 16:45:29 |
| Version : smp d R13 |
| Revision: R13.1.1-27-g8731a0d8c5 |
| Features enabled in this version: |
| Shared Memory Parallel |
| CESE CHEMISTRY EM ICFD STOCHASTIC_PARTICLES |
| FFTW (multi-dimensional FFTW Library) |
| ARPACK (nonsymmetric eigensolver library) |
| ANSYSLIC enabled |
| Licensed to: |
| Platform : WINDOWS X64 SSE2 |
| OS Level : Windows 8/10 & Srv 2016/2019/2022 |
| Compiler : Intel Fortran XE 2019 MSVC++ 2019 |
| Hostname : DESKTOP-VQTPO74 |
| Precision : Double precision (I8R8) |
| Unauthorized use infringes Ansys Inc. copyrights |
|___________________________________________________|[license/error] *** ANSYS LICENSE MANAGER ERROR ***
[license/error] Request name dyna does not exist in the licensing pool.
[license/error] No valid FLEXlm servers specified.
[license/error] Licensing mode "ANSYS LSDYNA" failed on feature "dyna". Undoing partial checkout.
Student license active; 295 days remaning.Executing with ANSYS license
Command line options: i=C:\Users\ST03\Desktop\file\project.proj
ncpu=2
memory=20mInput file: C:\Users\ST03\Desktop\file\project.proj
The native file format : 64-bit small endian
Memory size from command line: 20000000on UNIX computers note the following change:
ctrl-c interrupts ls-dyna and prompts for a sense switch.
type the desired sense switch: sw1., sw2., etc. to continue
the execution. ls-dyna will respond as explained in the users manualtype response
quit ls-dyna terminates.
stop ls-dyna terminates.
sw1. a restart file is written and ls-dyna terminates.
sw2. ls-dyna responds with time and cycle numbers.
sw3. a restart file is written and ls-dyna continues calculations.
sw4. a plot state is written and ls-dyna continues calculations.
swa. ls-dyna flushes all output i/o buffers.
swb. a dynain is written and ls-dyna continues calculations.
swc. a restart and dynain are written and ls-dyna continues calculations.
swd. a restart and dynain are written and ls-dyna terminates.
swe. stop dynamic relaxation just as though convergence
endtime=time change the termination time
lpri toggle implicit lin. alg. solver output on/off.
nlpr toggle implicit nonlinear solver output on/off.
iter toggle implicit output to d3iter database on/off.
prof output timing data to messag and continue.
conv force implicit nonlinear convergence for current time step.
ttrm terminate implicit time step, reduce time step, retry time step.
rtrm terminate implicit at end of current time step.
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LST nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. Users must verify their own *
* results. *
* LST endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LST through your site focus. *
* Copyright (C) 1990-2022 *
* by Ansys, Inc. *
* All rights reserved *
******** notice ******** notice ******** notice *********** Beginning to read structured input file ***
*** Error 20001 (STR+1)
input error found in structured input
reading 1st control card
line number 2 contains improperly formatted data
**************************************** line# 2
This problem may be solved by using long=s option.
ActiveLabels Start v-2E r r o r t e r m i n a t i o n 11/11/23 17:17:42
Memory required to complete solution : 0
Additional dynamically allocated memory: 1976K
Total: 1976KT i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
T o t a l s 1.0000E+00 100.00 1.0000E+00 100.00Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 1 seconds ( 0 hours 0 minutes 1 seconds)
CPU time per zone cycle = 0.000 picoseconds
Clock time per zone cycle=*************** picosecondsNumber of CPU's 1
How can I check line number 2 and how can I solve this error problem
Day after tommorow is my team presentation,
I would appreciate it if you could reply
November 16, 2023 at 11:44 am
Ashish Khemka
Forum ModeratorHi,
Based on the error message please check the format of line 2.
Ashish Khemka
- The topic ‘LS-DYNA Error 20001 (STR+1)’ is closed to new replies.
6410
