December 22, 2024 at 5:10 pm
kevin.podgorski
SubscriberHello,
I'm having an issue with HFSS only using half of the available CPU core during a solve. System:
AMD 9684X - 96 Core, SMT - Off, NPS - 4.
12x128gb DDR5 4800mhz
4x 2tb PCIe 5.0 NVMe in RAID 0 for temp directory
500+ available Workgoup licenses
Ansys 2024R2
Windows Server 2022
The system is set to use 96 cores, but during adaptive meshing and frequency sweep only 48 cores are used. If I set 192 cores under HPC options, all 96 cores are used. It's as if HFSS doesn't recognize that SMT is off. I'm not an expert Ansys user, simply the one who deployed the system, so any advice would be greatly appreciated. Thanks!
December 23, 2024 at 4:53 pm
Aymen Mzoughi
Ansys EmployeeSet the HPC option to "Auto" and let HFSS automatically choose the adequate ressources for the given simulation
December 23, 2024 at 10:08 pm
kevin.podgorski
SubscriberIs there any more detail you could give one this? This behavior happens with automatic settings applied. It seems like HFSS would use more than half of the cpu if its available?
5884
1306
