September 21, 2021 at 9:35 am
jesmed
SubscriberHi,
I've been using LS-DYNA for a while. Is there a list of Error and Warnings with an explanation?
With kind regards,
Jesus
September 21, 2021 at 3:52 pmRam Gopisetti
Ansys Employeecan you be more specific in what error or warning you are facing ?
there is whole lot of errors and Warnings which might originated from different aspects like (licencing, Materials,units mismatch, Improper Card definition, used Methods like (sph, spg, efg, iga etc), solver versions e.t.c).
Cheers, Ram
September 21, 2021 at 8:22 pmjesmed
SubscriberThanks Ram, in the past I have encountered several types of errors and warnings and I did not understand them.
I'd be interested to have the list of the most common ones (20-30), and the likely causes, and how to avoid them. I'm especially interested in Materials, divergence problems, etc, etc
Many thanks for your help.
Brgds Jesus
September 21, 2021 at 11:41 pmAndreas Koutras
Ansys EmployeeHello Jesus Each message has a unique integer id. For certain error and warning messages you can obtain further information than what is written in the messag and d3hsp files. If you know the message id in advance and you want to check if further information is available, please add the command msg=message_id in the execution line for LS-DYNA, in the same manner you specify the input file (i=input.k). This will not run LS-DYNA, but will just output the message. For example, try to execute:
lsdyna.exe msg=40500
msg=all will output a file d3msg that contains all the available messages.
If you need further details about a message, feel free to post a question on the forum.
September 22, 2021 at 6:26 amjesmed
SubscriberMany thanks Andreas. Right know I don't have a license, but I'm intending to purchase one soon. Could you please do lsydyna msg=all and send me the d3msg. Thank you very much. Jesus
September 22, 2021 at 7:38 amAndreas Koutras
Ansys EmployeeJesus, unfortunately, we cannot share files through the forum.
September 22, 2021 at 8:48 amjesmed
SubscriberOK. Never mind. Thank you for your help.
Viewing 6 reply threads- The topic ‘list of errors and warnings’ is closed to new replies.
6625
1311
