Systems
Systems
Topics related to Twin Builder, medini analyze, VRXPERIENCE and more.
Linux Solver Launch Failure Due to Missing Motif Library
    • Mathias Ngong
      Bbp_participant
      Hello Support,
      I am using Ansys 2025 R2 on a Linux system. The model meshes successfully, but when I start the solution, Mechanical displays:
      "An error occurred while starting the solver module."
      The terminal reports:
      ansys.e: error while loading shared libraries:
      libXm.so.4: cannot open shared object file:
      No such file or directory
      I have already attempted a reinstallation of Ansys, but the issue remains.
    • Noriko Uemura
      Bbp_participant
      This issue occurs because the Motif runtime library (libXm.so.4), which is required by Ansys, is missing from the Ubuntu system.
      Please install the libmotif-dev package using the following command:
      sudo apt-get update
      sudo apt-get install libmotif-dev
      Once the installation is complete, launch Ansys again and rerun the analysis. The solver module should start normally if the required library has been installed successfully.
