September 19, 2024 at 4:18 pm
drdmsthesis
SubscriberHi,
When exporting a solution within interconnected analysis systems, vertices on line bodies/beams are not being exported. How can this error be addressed?
For example, a nonlinear buckling analysis C is missing the vertices.
Also, bolt pre tension/pretension elements do not work on these beam elements in analysis "C"
Thank you
September 20, 2024 at 10:30 am
September 20, 2024 at 1:18 pm
drdmsthesis
SubscriberThanks Deepak,
The “create geometry” boxes were unticked in my case. The fix worked.
Also, how can beam elements remain “rigid” after transferring solution data so I can apply bolt pretension to a straight line/edge?
September 20, 2024 at 2:24 pm
Deepak
Ansys EmployeeCan you please explain the case in more detail? any images.
September 20, 2024 at 3:30 pm
drdmsthesis
