Lifting simulation
    • ChelsyClaire0328
      Hi how can i make a lifting simulation in Ansys where the structure i want to analyze will show different step of rotation, my structure will have a sling wire at both ends, starting at horizontal position until it reach vertical position, i attach an image for easy understanding.
      I have found a sample video in youtube showing how the structure will react when it rotates vertically
      https://youtu.be/VkPAkY0lYxE
      Thanks
      Hello ChelsyClaire,
      I have inserted the image from your attachment because ANSYS Staff cannot open attachments.
      • The video showed them using springs for the cables and you can do the same.
      • Let the left spring be fixed to ground.
      • You know the start and end points of the top of the right spring. Is the path between them a straight line?
      • If so, I suggest you create an extra body to attach the right spring to.
      • Under the connections folder, Insert a Translation Joint between Ground and the extra body.
      • Edit the coordinate system under the Joint to point the X axis along the line from the start to the end point.
      • Add a Joint Load, Displacement, using the distance between the start and end points.
      • Under Analysis Settings, turn on Large Deflection, turn on Auto Time Stepping.
      • Set the Initial, Minimum and Maximum Substeps to 100.
      • The model will have an Inertial load of Standard Earth Gravity.
      • Make this a two step analysis, where step 1, the Joint Displacement is zero, but the springs stretch due to gravity.
      • In step 2, the Joint Displacement occurs.
      If the endpoints are in the XY plane, you might add a Displacement BC of Z=0 to make the solution easier to compute.
    • ChelsyClaire0328
      Hi Peter,
      Can i do this under static structural?
      If so, I suggest you create an extra body to attach the right spring to. <<<<<<<<<<< The extra body that i will create will be at the right top position on step 1?
      Under the connections folder, Insert a Translation Joint between Ground and the extra body. <<<<< The ground will be the right top position of step 3?
      in step 1?
      Hi Claire,
      Yes, the extra body will be at the top of the spring and will travel along the dotted line.
    • ChelsyClaire0328
      Hi Peter,
      Is the arrangement going to be like this?
      Do i need to add only 1 extra body? which to be located at the initial positon of the right hook
      Then the last point will be the reference coordinate system point for Translational joint?
      Yes, but the X axis of the Joint Coordinate System is the translation axis, so you have to use the fields in the Detail window to orient the X axis to be parallel with the dotted line.
      Hi Claire,
      Here is an idea, put the coordinate system at the center of the orange circle with Z pointing out of the screen. Change the Translational Joint to a Revolute Joint.  The Load then becomes a rotation that takes the end of the spring along an arc. This will behave like a four-bar mechanism and will keep the tension in the springs much more even during the move.
      Peter
Viewing 6 reply threads
  • The topic ‘Lifting simulation’ is closed to new replies.
