August 24, 2022 at 6:48 pm
Edwin Burwell
I'm having difficulty getting the Client License Utility to save the license server. It generates this error:
Could not set flexNet servers: undefined.undefined.undefined.
August 25, 2022 at 2:22 am
Devendra Badgujar
Forum ModeratorHello Edwin Burwell
Please go through this article on ''Using the Ansys Client Settings Utility'' and see if that helps.Â
1.2. Using the Ansys Client Settings Utility
Also go through this FAQ: Resolving issue related to special characters in server name - Knowledge Base - Ansys Discovery Forum article to see if that is generating this error.
Let me know if further assistance is needed.Â
Regards.Â
August 25, 2022 at 10:43 am
August 25, 2022 at 10:53 am
Devendra Badgujar
Forum ModeratorEdwin BurwellÂ
Can you please share the diagnostic files as mentioned in this page?
Regards.
August 25, 2022 at 11:37 am
Edwin Burwell
Devendra BadgujarÂ
I found the problem. The client license utility need to be run as admin to write the ini file.
Thanks
- The topic ‘LICENSING PROBLEM’ is closed to new replies.
5819
