October 8, 2025 at 6:28 pm
October 10, 2025 at 2:42 pm
Rahul
Ansys EmployeeThe transition to solver mode may be failing because you are trying to use a license that is not included in your current license. Please launch the Fluent launcher and check the Capability Level. If it is set to 'Enterprise,' change it to the licence available to you, e.g, 'Premium', and then verify whether the same issue occurs.
October 10, 2025 at 11:36 pm
mydogdodge10
SubscriberThe same issue occurs, I tried both Pro and Premium settings. This started when I accidentally made a model with too many nodes for the student version and tried to import it into the solver, if that helps at all. I went back to using less nodes than the max, but I'm still getting the license error. Any other ideas?
October 12, 2025 at 3:48 am
Rahul
Ansys EmployeeTry clearing temporary files.Â
- Close all running Ansys applications.Â
- In your Windows search bar, type %APPDATA%. Go to the folder that appears.Â
- Navigate to the Ansys folder. There should be a folder inside called v2xx.Â
- The exact numbers will vary based on the version of Ansys you are using. v242 corresponds to Ansys 2024R2, v231 corresponds to Ansys 2023R1, and so on.
- Rename v2xx to v2xxold. When you start Ansys again, Ansys will automatically create a new v2xx folder.
October 13, 2025 at 1:02 am
mydogdodge10
SubscriberI just went through that process, and I am getting the exact same error. Any other ideas?
October 14, 2025 at 3:16 am
mydogdodge10
SubscriberJust encountered a new situation which may shed some light. I changed the router DNS server from adgaurd to default, and used the default mesh size in fluent, and the fluent solver worked again with no error. However, when I tried to change the mesh sizing of my geometry in the fluent mesher, it went back to giving me the same error as above. I then tried to use the default mesh size and it still didnt work. It looks like for some reason when I mesh a geo using too many nodes for the student version, it disables my license permanently or something. Any ideas?
6765
1330
1097
