LS Dyna
LS Dyna
License error problem in student version
    • joaovitorsantiago27
      I am a doctoral student in nuclear engineering and am facing a license issue ("License not found") in the student version of LS-DYNA (R16.1). This is the latest version. I've uninstalled and reinstalled it, but the issue persists. Thank you in advance.
    • 2300070010
      so regarding license error, if you have previously used ansys in your desktop and later deleted and trying to install new version then you will get the licence error to solve it you should uninstall all ansys related files from your storage including souce file like go to program files and deleted ansys license folder and related files and then reinstall then it might work
      Thank you so much. I got it, it's fixed now, but only when I run is LS-RUN, but I'd like to run from spyder IDE using python. It seems I can't do it using student license.
