September 27, 2023 at 2:47 am
September 27, 2023 at 12:06 pm
Rajeshwari Jadhav
Forum ModeratorHi Yiting,
Check if you have the feature "lum_fdtd_gui" in your license file.
If yes then, can you make entries in the host file: (You will require admin access)
·       Open the HOSTS file on the client machine and add the license server name and IP of the license server in that hosts file.
·       Path: “C:\Windows\System32\drivers\etc “ as per the following format in your client machine :
Example:
IP address of server      Hostname of server           FQDN   Â
xxx.xxx.xxx.xxx          Â
                                      //IP address of server and name. You can also add FQDN. Â
·       Add the below-mentioned line at the end of hosts file.
    ·       Once the entry is added save the file.
·       Launch the Ansys application.
If you face any issues, send screenshot of it.
- The topic ‘License connection issue’ is closed to new replies.
5649
1885
1404
1303
.png)
