November 6, 2023 at 10:00 am
Mostafa Shahata
SubscriberI have a problem when make a simulation of laser bending process
November 6, 2023 at 10:15 am
ErKo
Ansys EmployeeHi
Can you please provide much more details on what you mean with laser bending, and what you would like to simulate. The more info provided the more feedback forum members can give.
All the best
Erik
November 6, 2023 at 12:23 pm
Mostafa Shahata
SubscriberThe laser bending process means using laser power to deform sheet metal. To make the simulation, first add a moving heat source to the temperature distribution model, then use this temperature model as a force to bend sheet metal. when started to solve the transient thermal model, massage appears (unknown problem occurs) despite already meeting all requirement
November 6, 2023 at 12:35 pm
ErKo
Ansys EmployeeHi - that is good.
I believe in theory we should be able to predict this.
Can you post some images of your set up in Mechanical (say for the heat source/moving flux or)?
ALso see if there are any messages/errors in the SOlver Output in the Solution Information.All the best
Erik
November 6, 2023 at 12:56 pm
November 6, 2023 at 1:02 pm
ErKo
Ansys EmployeeHi
You are using the act extension which should work in principle.
I would suggest to use the transient thermal and use the moving heat flux, and not energy (that worked for me).
Also look through a tutorial to make sure it is set up ok.
https://www.youtube.com/watch?v=KuGyVu7H4gU
All the best
Erik
November 6, 2023 at 1:06 pm
Mostafa Shahata
SubscriberActually, I used transient thermal and the moving heat flux before, the same unknown error occurs
November 6, 2023 at 1:39 pm
November 6, 2023 at 1:41 pm
Mostafa Shahata
SubscriberI think the problem about temperature
- The topic ‘laser bending’ is closed to new replies.
5654
1890
1404
1303
