Krishna_M_j
    • Krishna_M_j
      I am using 2020 R2 version ansys fluent. I can't turn off the viscous model ( and all other models) once it is turned on. Is there a way to do this, please reply I am new to fluent
    • Karthik Remella
      Administrator
      Hello You should be able to switch to Inviscid (under Viscous Model). Does this not work for you?
      Karthik
    • Krishna_M_j
      Yes I tried , but the results are not good
    • Karthik Remella
      Administrator
      What are you modeling? Please share some problem details so we can understand the issue betteR?
      Karthik
    • Krishna_M_j
      I am modeling a LiFePo4 cell (MSMD- NTGK) with PCM cooling . I need to plot graphs of temperature (cell) vs time with PCM and Without PCM.
      We are also doing this model in real world. Now having trouble with matching the actual data and data from the simulation
Viewing 4 reply threads
  • The topic ‘Krishna_M_j’ is closed to new replies.
