Joint force probe output data in global reference frame.
    • josegegas
      Hello.
      When one adds a joint probe to a rigid dynamics simulation, for instance to read joint force or torque, by default Ansys outputs the values expressed in the reference frame of the joint:
      I would like the values expressed in the global reference frame, but Ansys does not give this option in the dialog. How can I do this?
      Thank you in advance.
    • harshvardhan.negi
      In Ansys Rigid Dynamics solver, the joint constraint forces and moments are always reported in the joint reference coordinate system. If you need the values in the global reference frame, you might need to perform a coordinate transformation outside of Ansys.
      Harshvardhan
      Ansys Help
      Ansys Learning Forum (Rules & Guidelines)
    • dlooman
      If you only have 1 or 2 joints you could use the command fsum to get the joint forces in global coordinates.  The procedure would be to create a named selection for one of the faces the joint is scoped to and then issue the commands below:
      cmsel,s,face_name
      fsum
      allsel
