December 21, 2021 at 8:19 am
Theo
Subscriber老师您好
This is an embed external element. It can be deleted using the delete key or the backspace key. To view the full element, press the preview button below.FDTDu95eeu9898.pdf178.19 KB -
December 21, 2021 at 5:21 pm
Guilin Sun
Ansys Employee因为后面的空气是均匀介质,一般不必要仿真如此长的距离,你只需要仿真一点距离,加一个监视器,然后用farfieldexact 计算任意距离的Ansys Insight: 关于farfieldexact及其应用。
结果很差由很多原因,其中之一就是衍射:仿真区横向尺寸(透镜直径方向)要足够大,透镜也要足够大。如果透镜很小,衍射非常严重,准直的可能性很小。注意仿真无法突破物理原理,除非你的设计全面考虑了这些。
December 27, 2021 at 2:09 am
December 28, 2021 at 12:30 am
Guilin Sun
- The topic ‘几何透镜转超构透镜失败的原因?(透镜功能:高斯转平顶光)’ is closed to new replies.
Ansys Innovation Space
1414
1256
1118
1015
