July 26, 2021 at 6:08 pm
redrout
SubscriberHello,
I'm seeming to have some problems with the FLUENT application. When launching (either from workbench or from the dedicated launcher), the application hangs up on starting. It displays the window and toolbars, but none of these can be interacted with. After a few minutes, this error appears.
July 27, 2021 at 8:37 amRob
Forum ModeratorWhen you open the Fluent launcher set the Parallel Settings "Select IP Interface" to 127.0.0.1 You may also need to set the MPI type to msmpi but try the fixed IP first.
July 27, 2021 at 5:24 pmJuly 28, 2021 at 8:43 amRob
Forum ModeratorThat may be the firewall, or will know more - I just drive the software!
July 28, 2021 at 1:23 pmGeorge Karnos
Ansys Employee@redrout Some other (non-ANSYS) software installation may put older version Intel Compiler dynamic link library (e.g. 2017) files under C:\Windows\system32, including:
libchkp.dll
libgfxoffload.dll
libicaf.dll
libifcoremd.dll
libifcoremdd.dll
libifcorert.dll
libifcorertd.dll
libifportmd.dll
libioffload_host.dll
libiomp5md.dll
libiompstubs5md.dll
libirngmd.dll
libmmd.dll
libmmdd.dll
libmpx.dll
liboffload.dll
Rename C:\Windows\system32\libmdd.dll (e.g. to libmdd.dll.old) may resolve the issue.
Also suggest rename (delete or move) other Intel Complier dynamic link library files in above list in C:\Windows\system32, and notify other (non-ANSYS) software vendor not to put such files in C:\Windows\system32, since different applications may need different versions Intel Complier dynamic link library.
If that does not help, please also send the full output of running the "set" command from a command prompt.
Best Geo
July 28, 2021 at 5:06 pmredrout
SubscriberThanks a ton for the help, this was what was causing the hangup apparently.
Viewing 5 reply threads- The topic ‘Issues with FLUENT application’ is closed to new replies.
5729
