Issues Using ifort24/ifx Compiler with UserMat Package Built on ifort19
TAGGED: compiler, fortran, udf-compiler-problem, windows-compilers
June 27, 2025 at 7:07 pm
Amrith Mariappan
SubscriberHi all,
I’ve been trying to use the ifort24/ifx compiler for a static linking UDF approach in ANSYS LS-DYNA. When I compile with ifort24, I get linker errors that seem related to a version mismatch, likely because the UserMat package libraries were built with ifort19.
My university IT department is having trouble locating ifort19, and I haven’t been able to find a UserMat package library built with ifort24 or ifx. I’m wondering if anyone can help me resolve this error or suggest if it’s possible to use ifort24 or ifx with libraries built on ifort19.
I’ve attached the linker error I’m getting during the make process for reference.
Thanks,
Amrithifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '/Qdiag-disable:10448' to disable this message.ipo: warning #11082: libansys.lib(zutil.obj): locally defined symbol __imp_free importedipo: warning #11082: libansys.lib(zutil.obj): locally defined symbol __imp_malloc importedMicrosoft (R) Incremental Linker Version 14.44.35211.0Copyright (C) Microsoft Corporation. All rights reserved.-out:mppdyna.exe-subsystem:console-stack:1610612736-force/nodefaultlib:msvcrt.lib-ignore:4217-ignore:4049/nodefaultlib:libifcoremd.liblibdyna.liblibansys.liblibcmt.libgdi32.libcomdlg32.libUser32.libcomctl32.libws2_32.libadvapi32.libnetapi32.libshell32.libiphlpapi.libmkl_intel_ilp64.libmkl_sequential.libmkl_core.lib"/libpath:c:\Program Files (x86)\IntelSWTools\MPI\2019.6.166\intel64\lib"impi.libcouple2other_user.objdyn21cnt.objdyn21ueos.objdyn21umats.objdyn21ushl.objdyn21utan.objdyn21.objdyn21tumat.objdyn21umatc.objdyn21umatv.objuserinterface.objdyn21usld.objdynrfn_user.objdyn21umat.objinit_dyn21.objdyn21em.objdyn21icfd.objdyn21.obj : warning LNK4006: UMAT41 already defined in dyn21umats.obj; second definition ignoredCreating library mppdyna.lib and object mppdyna.expdyn21.obj : error LNK2019: unresolved external symbol VALOCR referenced in function UTHMAT01mppdyna.exe : warning LNK4088: image being generated due to /FORCE option; image may not rundyn21.obj : fatal error LNK1223: invalid or corrupt file: file contains invalid .pdata contributionsNMAKE : fatal error U1077: 'ifort' : return code '0x4c7'Stop.Makefile Content:## Makefile for building mppdyna Windows 64 bits# for 'Intel MPI'# Flags for single and double precisionFC = ifortMPPS =MPPD = -DEXTENDED -DUSES_CXX -DAUTODOUBLE -4R8 -4I8TARGET = mppdyna.exeFLAGS = /c /traceback /assume:byterecl /QxSSE2 -fp:precise /Quppercase \/fpp /DIA64 /DMSTI /DAMD64 /DWINX64 /DNET_SECURITY /DMPP /DMPPWIN \/w /WB /DINTEL /DNET_SECURITY /D__VC__MPICH_LIB =/libpath:"c:\Program Files (x86)\IntelSWTools\MPI\2019.6.166\intel64\lib" \impi.libMPICH_INC_PATH = "c:\Program Files (x86)\IntelSWTools\MPI\2019.6.166\intel64\include"FFLAGS = $(FLAGS) -I. -I$(MPICH_INC_PATH) $(MPPD)LINKLIBS = libdyna.lib libansys.lib libcmt.lib gdi32.lib comdlg32.lib User32.lib \comctl32.lib ws2_32.lib advapi32.lib netapi32.lib shell32.lib iphlpapi.lib \mkl_intel_ilp64.lib mkl_sequential.lib mkl_core.lib $(MPICH_LIB)OBJS= couple2other_user.obj dyn21cnt.obj dyn21ueos.obj dyn21umats.obj dyn21ushl.obj \dyn21utan.obj dyn21.obj dyn21tumat.obj dyn21umatc.obj dyn21umatv.obj userinterface.obj \dyn21usld.obj dynrfn_user.obj dyn21umat.obj init_dyn21.obj dyn21em.obj dyn21icfd.obj$(TARGET): $(OBJS)$(FC) -w -q -o $(TARGET) $(OBJS) -F:1610612736 -link -force /nodefaultlib:msvcrt.lib \-ignore:4217 -ignore:4049 /nodefaultlib:libifcoremd.lib $(LINKLIBS)$(OBJS) :nhisparm.inc.F.obj:$(FC) $(FFLAGS) $*.F.F90.obj:$(FC) $(FFLAGS) $*.F90clean:-if exist *.obj erase *.obj# -if exist del $(OBJS)-if exist $(TARGET) erase $(TARGET) -
July 3, 2025 at 7:50 pm
Pedram Samadian
Ansys EmployeeHi Amrith,
The current LS-DYNA solvers work based on the “ifort” Intel Fortran compiler. For Intel versions after 2024, “ifort” was switched to “ifx”, and UserMat packages have not yet been adapted to this change. To make them work for those Intel versions, you need to open the “makefile” in the unpacked solver folder using a text reader software such as notepad or notepad++ and then change the reference to “ifort” to “ifx”.
I hope this helps.
Thanks,
Pedram
July 3, 2025 at 9:28 pm
Amrith Mariappan
SubscriberHi, Thank you so much. I was able to compile it successfully.
Amrith
July 4, 2025 at 1:49 pm
Pedram Samadian
Ansys EmployeeGreat. You're welcome.
Pedram
5639
1885
1403
1303
