February 27, 2024 at 12:22 am
Patrick Chan
SubscriberI am having issues importing 3D models (.obj files) into Maxwell, I keep getting "parasolid entity check failed for the part". How does one resolve this error?
February 29, 2024 at 8:00 pm
GLUO
Ansys EmployeeHi,
Are you using 2024R1 version? Does this error message pop at solving stage or just after the import? If it is already imported, please try seleting all objects, modeler>>export them as parasolid format or STEP file format, and reimport them. In this way the geometry should be reformatted correctly as parasolid.Â
GL
March 1, 2024 at 4:56 am
Patrick Chan
SubscriberYes I am using 2024R1 version.
This message shows up when validating, trying to import the .obj then exporting to parasolid or STEP then reimporting it comes to the same issue.
- The topic ‘Issues importing 3D models (.obj files) into Maxwell’ is closed to new replies.
