March 6, 2019 at 3:41 pm
drodriguez41912
SubscriberHi all,Â
I have been trying to install ansys 18.2 onto my laptop. I downloaded the two disks from my school website, and ran as administrator the setup.exe. I left the default settings for the path. During the installation process I selected the second disk when prompted
I will attach the error log if anyone can take a look?
thanks,
March 6, 2019 at 5:41 pm
tsiriaks
Ansys EmployeeHi drodriguez41912,
Have you tried moving the 'unzipped' installation package to C drive , then run the 'setup.exe' with 'run as admin' from there ?
If issue persists, please post the content of 'install.log' and 'install.err' files in this post, don't attach the files.
Thanks,
Win
March 6, 2019 at 6:29 pm
drodriguez41912
SubscriberHi Win,
So I put the unzipped files, disk1 & 2 in my local C drive. I tried run as administrator from the setup.exe and tried installing again and the same issue occurred.Â
I will post the install.err text below
ANSYS installation: Wed Mar 6 13:19:17 2019
Revision: Release 18.2
  ###### Error #######
  Error extracting H:commonWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:commonWINX64.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpcommonHLPCOMMON.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpcommonHLPCOMMON.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpviewerHLPVIEWER.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpviewerHLPVIEWER.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpmechanicalHLPMECHANICAL.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpmechanicalHLPMECHANICAL.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpacpHLPACP.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpacpHLPACP.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpautodynHLPAUTODYN.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpautodynHLPAUTODYN.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpaimHLPAIM.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpaimHLPAIM.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpserverHLPSERVER.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpserverHLPSERVER.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpcfxHLPCFX.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpcfxHLPCFX.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpcfdpostHLPCFDPOST.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpcfdpostHLPCFDPOST.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:fluentWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:fluentWINX64.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpfluentHLPFLUENT.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpfluentHLPFLUENT.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:turbogrdWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:turbogrdWINX64.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpturbogridHLPTURBOGRID.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpturbogridHLPTURBOGRID.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:fensapWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:fensapWINX64.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpfensapHLPFENSAP.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpfensapHLPFENSAP.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlppolyflowHLPPOLYFLOW.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlppolyflowHLPPOLYFLOW.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:forteWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:forteWINX64.7z" "-oC:Program FilesANSYS Incv182reaction"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpforteHLPFORTE.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpforteHLPFORTE.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:chemkinWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:chemkinWINX64.7z" "-oC:Program FilesANSYS Incv182reaction"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:icemcfdWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:icemcfdWINX64.7z" "-oC:Program FilesANSYS Incv182icemcfdwin64_amd"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:cadsspatialWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:cadsspatialWINX64.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:instutilINSTUTIL.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:instutilINSTUTIL.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpicemcfdHLPICEMCFD.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpicemcfdHLPICEMCFD.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpoffshoreHLPOFFSHORE.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpoffshoreHLPOFFSHORE.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpaviewHLPAVIEW.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpaviewHLPAVIEW.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:icepakWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:icepakWINX64.7z" "-oC:Program FilesANSYS Incv182"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpicepaksaHLPICEPAKSA.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpicepaksaHLPICEPAKSA.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:hlphlpicepakHLPICEPAK.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:hlphlpicepakHLPICEPAK.7z" "-oC:Program FilesANSYS Incv182commonfiles"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:ecadxltrWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:ecadxltrWINX64.7z" "-oC:Program FilesANSYS Incv182Electronics"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  Error extracting H:electroWINX64.7z:
  '"C:UsershelpmAppDataLocalTempans_install_tmp183407zip7z.exe" x -aoa -bb1 "H:electroWINX64.7z" "-oC:Program FilesANSYS Incv182Electronics"' terminated after 1 attempts with the following error(s):
      Unknown error
  Exit Code: 2
  couldn't execute "C:Program FilesANSYS Incv182commonfileshelpHelpViewerIndexerANSYSHelpIndexer.exe": no such file or directory
March 6, 2019 at 6:30 pm
drodriguez41912
Subscriberand this is the install.log file
Start Installation: Wed Mar 6 12:55:03 2019
Platform specifics:
   Windows
Username of Installer: DESKTOP-G0RLAVHhelpm
User Has Administrator Privileges
C:UsershelpmAppDataLocalTempans_install_tmp18340instcore.exe -usetempdir C:UsershelpmAppDataLocalTempans_install_tmp18340 -launchdir G: -admin
Initial mount directory:
   G:
Installation Directory:
Windows x64
    ANSYS, Inc. Products
         ANSYS Structural Mechanics
              ANSYS Mechanical Products
              ANSYS Customization Files for User Programmable Features
         ANSYS Explicit Dynamics
              ANSYS Autodyn
         ANSYS AIM
         ANSYS Fluid Dynamics
              ANSYS CFX (includes ANSYS CFD-Post)
              ANSYS Fluent (includes ANSYS CFD-Post)
              ANSYS TurboGrid
              ANSYS FENSAP-ICE
              ANSYS Polyflow (includes ANSYS CFD-Post)
              ANSYS CFD-Post only
              ANSYS Forte
              ANSYS Chemkin
                   ANSYS Energico
                   ANSYS Reaction Workbench
                   ANSYS Model Fuel Library (Encrypted)
         ANSYS ICEM CFD
         ANSYS Offshore
              ANSYS Aqwa
    ANSYS Additional Tools
         ANSYS Viewer
         ANSYS Icepak (includes ANSYS CFD-Post)
    ANSYS Geometry Interfaces
         AutoCAD
         ACIS
         Catia, Version 5
         Catia, Version 6
         Creo Elements/Direct Modeling
         Inventor
         JTOpen
         NX
         Parasolid
         Creo Parametric
         Solid Edge
         SolidWorks
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You don't need to install any prerequisites.
Reading the installation media contents - please wait.
 Extraction: G:framewrkWINX64.7z ...
 Extraction: G:instcoretclCOMMON.TGZ ...
 Extraction: G:instcoretclWINX64.TGZ ...
 Extraction: G:instutilINSTUTIL.7z ...
 Extraction: G:instcoretkCOMMON.TGZ ...
 Extraction: G:instcoretkWINX64.TGZ ...
 Extraction: G:configsclientlicensingWINX64.7z ...
 Extraction: G:sgchartsWINX64.7z ...
 Extraction: G:configscommonWINX64.7z ...
 Extraction: G:cpythextWINX64.7z ...
 Extraction: G:cpythnewWINX64.7z ...
 Extraction: G:configshelpWINX64.7z ...
 Extraction: G:tpWINX64.7z ...
 Extraction: G:configswbWINX64.7z ...
 Extraction: G:addinsWINX64.7z ...
 Extraction: G:addinsansoftWINX64.7z ...
 Extraction: G:addinsmatdesWINX64.7z ...
 Extraction: G:addincfgwbWINX64.7z ...
 Extraction: G:corewbWINX64.7z ...
 Extraction: G:cadsspatialWINX64.7z ...
 Extraction: G:rsmWINX64.7z ...
 Extraction: G:icemwbWINX64.7z ...
 Extraction: G:addincfgturbosysWINX64.7z ...
 Extraction: G:cadsacisparaWINX64.7z ...
 Extraction: G:addincfgekmWINX64.7z ...
 Extraction: G:ekmWINX64.7z ...
 Extraction: G:secWINX64.7z ...
 Extraction: G:configsspaceclmWINX64.7z ...
 Extraction: G:ccmWINX64.7z ...
 Extraction: G:ecadxltrWINX64.7z ...
 Extraction: G:electroWINX64.7z ...
 Extraction: G:cadsspatialiopWINX64.7z ...
 Extraction: G:ansysWINX64.7z ...
 Extraction: G:configsansysWINX64.7z ...
 Extraction: G:addincfgansysWINX64.7z ...
 Extraction: G:addincfgmatdesWINX64.7z ...
 Extraction: G:solverWINX64.7z ...
 Extraction: G:aasWINX64.7z ...
 Extraction: G:dataDATA.GZ ...
 Extraction: G:apdlAPDL.GZ ...
 Extraction: G:geomparaWINX64.7z ...
 Extraction: G:addincfgmechWINX64.7z ...
 Extraction: G:acpWINX64.7z ...
 Extraction: G:addinsacpWINX64.7z ...
 Extraction: G:configsacpWINX64.7z ...
 Extraction: G:anscustWINX64.7z ...
 Extraction: G:autodynWINX64.7z ...
 Extraction: G:addincfgautodynWINX64.7z ...
 Extraction: G:asimWINX64.7z ...
 Extraction: G:configsasimWINX64.7z ...
 Extraction: G:afdWINX64.7z ...
 Extraction: G:configsafdWINX64.7z ...
 Extraction: G:afdrunWINX64.7z ...
 Extraction: G:electaimWINX64.7z ...
 Extraction: G:configspolyflowWINX64.7z ...
 Extraction: G:cadsacadWINX64.7z ...
 Extraction: G:cadscat5WINX64.7z ...
 Extraction: G:cadsdatakitWINX64.7z ...
 Extraction: G:cadsosmWINX64.7z ...
 Extraction: G:cadsaiWINX64.7z ...
 Extraction: G:geomunigWINX64.7z ...
 Extraction: G:cadsnxWINX64.7z ...
 Extraction: G:geomproeWINX64.7z ...
 Extraction: G:cadspeWINX64.7z ...
 Extraction: G:cadsseWINX64.7z ...
 Extraction: G:cadsswWINX64.7z ...
 Extraction: G:licenseWINX64.7z ...
 Extraction: G:hlphlplicHLPLIC.7z ...
 Extraction: H:commonWINX64.7z ...
 Extraction: H:hlphlpcommonHLPCOMMON.7z ...
 Extraction: H:hlphlpviewerHLPVIEWER.7z ...
 Extraction: H:spaceclmWINX64.7z ...
 Extraction: H:cfxcomonWINX64.7z ...
 Extraction: H:hlphlpmechanicalHLPMECHANICAL.7z ...
 Extraction: H:hlphlpacpHLPACP.7z ...
 Extraction: H:hlphlpautodynHLPAUTODYN.7z ...
 Extraction: H:hlphlpaimHLPAIM.7z ...
 Extraction: H:hlphlpserverHLPSERVER.7z ...
 Extraction: H:polyflowWINX64.7z ...
 Extraction: H:cfxWINX64.7z ...
 Extraction: H:addincfgcfxWINX64.7z ...
 Extraction: H:configscfxWINX64.7z ...
 Extraction: H:hlphlpcfxHLPCFX.7z ...
 Extraction: H:postWINX64.7z ...
 Extraction: H:addincfgcfdpostWINX64.7z ...
 Extraction: H:hlphlpcfdpostHLPCFDPOST.7z ...
 Extraction: H:fluentWINX64.7z ...
 Extraction: H:fluentcWINX64.7z ...
 Extraction: H:addincfgfluentWINX64.7z ...
 Extraction: H:configsfluentWINX64.7z ...
 Extraction: H:hlphlpfluentHLPFLUENT.7z ...
 Extraction: H:configscfdpostWINX64.7z ...
 Extraction: H:turbogrdWINX64.7z ...
 Extraction: H:addincfgturbosysWINX64.7z ...
 Extraction: H:configstgWINX64.7z ...
 Extraction: H:hlphlpturbogridHLPTURBOGRID.7z ...
 Extraction: H:fensapWINX64.7z ...
 Extraction: H:configsfensapWINX64.7z ...
 Extraction: H:hlphlpfensapHLPFENSAP.7z ...
 Extraction: H:addincfgpolyflowWINX64.7z ...
 Extraction: H:configspolyflowWINX64.7z ...
 Extraction: H:hlphlppolyflowHLPPOLYFLOW.7z ...
 Extraction: H:forteWINX64.7z ...
 Extraction: H:addincfgforteWINX64.7z ...
 Extraction: H:configsforteWINX64.7z ...
 Extraction: H:hlphlpforteHLPFORTE.7z ...
 Extraction: H:configschemkinWINX64.7z ...
 Extraction: H:chemkinWINX64.7z ...
 Extraction: H:configsenergicoWINX64.7z ...
 Extraction: H:configsrdworkbenchWINX64.7z ...
 Extraction: H:icemcfdWINX64.7z ...
 Extraction: H:configsicemcfdWINX64.7z ...
 Extraction: H:configscommonWINX64.7z ...
 Extraction: H:cadsspatialWINX64.7z ...
 Extraction: H:configshelpWINX64.7z ...
 Extraction: H:instutilINSTUTIL.7z ...
 Extraction: H:hlphlpicemcfdHLPICEMCFD.7z ...
 Extraction: H:addincfgicemcfdWINX64.7z ...
 Extraction: H:ccmWINX64.7z ...
 Extraction: H:aqwaWINX64.7z ...
 Extraction: H:addincfgaqwaWINX64.7z ...
 Extraction: H:configsaqwaWINX64.7z ...
 Extraction: H:hlphlpoffshoreHLPOFFSHORE.7z ...
 Extraction: H:aviewWINX64.7z ...
 Extraction: H:configsaviewWINX64.7z ...
 Extraction: H:hlphlpaviewHLPAVIEW.7z ...
 Extraction: H:icepakWINX64.7z ...
 Extraction: H:addincfgicepakWINX64.7z ...
 Extraction: H:configsicepakWINX64.7z ...
 Extraction: H:hlphlpicepaksaHLPICEPAKSA.7z ...
 Extraction: H:hlphlpicepakHLPICEPAK.7z ...
 Extraction: H:ecadxltrWINX64.7z ...
 Extraction: H:electroWINX64.7z ...
RSS is disabled
Performing licensing configuration via the following command...
  "C:Program FilesANSYS IncShared Filesbinwinx64tclsh.exe" "C:Program FilesANSYS IncShared FilesLicensinglicadminscriptsLicAdminMain.itcl" -silentinstallclient -release "18.2" -licserverinfo 2325:1055:ucslic1.ucs.njit.edu -lang en-us
Licensing configuration has completed.
Creating Start menu items for ANSYS client licensing ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigCommon.exe
Configuring Help ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigHelp.exe
Running "C:Program FilesANSYS Incv182commonfileshelpHelpViewerIndexerANSYSHelpIndexer.exe" -removePreviousIndex -operation MERGE_FORMAT -inputDir "C:Program FilesANSYS Incv182commonfileshelpen-us" -outputDir "C:Program FilesANSYS Incv182commonfileshelpen-usLuceneIndex" -format "LuceneIndex_*"
Running "C:Program FilesANSYS Incv182commonfileshelpHelpViewerIndexerANSYSHelpIndexer.exe" -removePreviousIndex -operation AUTO -inputDir "C:Program FilesANSYS Incv182commonfileshelpen-usLuceneIndex" -outputDir "C:Program FilesANSYS Incv182commonfileshelpen-usAutoCompleteIndex"
Running "C:Program FilesANSYS Incv182commonfileshelpHelpViewerIndexerANSYSHelpIndexer.exe" -removePreviousIndex -operation SPELL -inputDir "C:Program FilesANSYS Incv182commonfileshelpen-usLuceneIndex" -outputDir "C:Program FilesANSYS Incv182commonfileshelpen-usSpellCheckerIndex"
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigWB.exe
Running C:Program FilesANSYS Incv182FrameworkbinWin64Ans.DriverSetup.exe
Driver settings not implemented for this configuration.
Running "C:Program FilesANSYS Incv182RSMbinAnsConfigRSM.exe" -encodingUTF8
Configuring RSM...
Configuring default RSM and ARC Port numbers for Release 18.2 ...
Done!
User has Administrator privileges
Creating Start Menu Shortcut for RSM Release 18.2 Configuration...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 18.2Remote Solve ManagerRSM Configuration 18.2.lnk
Creating Start Menu Shortcut for RSM Release 18.2 Job Monitor...
Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 18.2Remote Solve ManagerRSM Job Monitoring 18.2.lnk
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigANSYS.exe
Adding write permissions for Users and Administrators group ...
Configuring ACP ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigACP.exe
Configuring AIM ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigAIM.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigCFX.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigFLUENT.exe
Configuring ANSYS CFD Post ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigCFDPost.exe
Configuring ANSYS TurboGrid ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigTG.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigFENSAP.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigPolyflow.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigFORTE.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigEnergico.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigRDWorkbench.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigICEMCFD.exe
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigAQWA.exe
Configuring ANSYS Viewer ...
Running C:Program FilesANSYS Incv182commonfilesconfigswinx64configAnsConfigIcepak.exe
Running "C:Program FilesANSYS Incv182aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe"
C:Program FilesANSYS Incv182..CADConfigurationMgr.log does not exist, not backed-up.
MessageLogger.logFilePath is C:Program FilesANSYS Incv182..CADConfigurationMgr.log
MessageLogger.errorFilePath is C:Program FilesANSYS Incv182..CADConfigurationMgr.err
SCDM Workbench PlugIn
CatiaV5 WorkBench Reader
CatiaV6 Workbench Reader
JTÂ Workbench Reader
CPÂ Workbench PlugIn
SWÂ Workbench Reader
AIÂ Workbench Reader
ACADÂ Workbench Reader
CED Workbench PlugIn
SEÂ Workbench Reader
The installation completed with warnings/errors. Review any .err or .log files in:
Installation Complete: Wed Mar 6 13:19:17 2019
Installation Complete. Please review the above information.
Thanks for choosing ANSYS Products!
***IMPORTANT***
After completing this installation, you need to run the ANSYS, Inc. License Manager installation on each machine designated as a license server. These machines may have been specified during this installation or may have been previously specified.
thank you,
David
March 6, 2019 at 7:02 pm
tsiriaks
Ansys EmployeeHi David,
Thanks for the log. Can you check if Disk 2 is mounted correctly ? Also, please right click on Disk 2 iso file -> Properties , then post the screenshot of it here.
Thanks,
Win
March 6, 2019 at 8:25 pm
March 6, 2019 at 9:36 pm
tsiriaks
Ansys Employeeaha ! That's the issue.
The size of the disk 2 is not correct.
You are supposed to have
4.03 GB (4,329,308,160 bytes)
on the 'Size:'Â Â line.
Please check your school website again. Not sure if it's the issue when you download from it. Or your IT upload it incompletely.Â
Thanks,
Win
March 7, 2019 at 1:36 am
drodriguez41912
SubscriberI see this makes sense now. I redownloaded the second disk and now its giving me 4227840 bytes instead of the full amount. I will contact my schools IT department and see how to resolve this with them. If I get the full files and there are further issues I will let you know.Â
Otherwise, thank you for your time Win,
David
March 7, 2019 at 5:11 pm
tsiriaks
Ansys EmployeeSounds good. Thanks David.
Please keep us posted how it goes whether it's good or bad.
Thanks,
Win
- The topic ‘Issue installing the ansys 18.2’ is closed to new replies.
6710
1313
