Ansys Free Student Software
Issue – installer stuck at 96%, at Configuring ANSYS Viewer
    • SSTan
      I have tried download the latest student Ansys 2019 R3 but it kept hanging on 96%, where it's trying to configuring ANSYS Viewer for hours.
      I have actually try to install on both of my drivers (Drive C and Drive D) thinking it might be my driver issue.
      but I found out that at Driver C my installation is "complete with error" where the file size is only 4GB
      while Driver D kept on stuck at 96% but with a file size of 40GB.
      I tried to uninstall both of them but they also stuck at 0%.
      Please help ~
      Thanks
      SSTAN
    • SSTan
      The detailed process log is as below :
      Start Installation: Fri Feb 14 16:48:51 2020
      Revision: 2019 R3
      Platform specifics:
      Windows
      Username of Installer: MSITanSo
      User Has Administrator Privileges
      C:UsersTanSoAppDataLocalTempans_install_tmp3344instcore.exe -usetempdir C:UsersTanSoAppDataLocalTempans_install_tmp3344 -launchdir C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64 -admin
      Initial mount directory:
      Installation Directory:
      D:ANSYS Inc
      Windows x64
      Date verification complete...No conflicts found.
      The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
      This may take a while ...
      Successfully copied prerequisites from media.
      You don't need to install any prerequisites.
      Reading the installation media contents - please wait.
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64framewrkWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64instcoretclCOMMON.TGZ ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64instcoretclWINX64.TGZ ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64commonWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64commoninstallWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configscommonWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cpythextWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cpythnewWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64turbogrdWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configstgWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cfxcomonWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64instutilINSTUTIL.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64instcoretkCOMMON.TGZ ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64instcoretkWINX64.TGZ ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsclientlicensingWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configswbWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64sgchartsWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fwgfxWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addinsWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgwbWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64corewbWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cadscadaisolWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cadscadregistryWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64ekmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgekmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgminervaWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64meshingWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64blademodelerWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64apipsrvWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64designmodelerWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64syscplgWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64rsmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgturbosysWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64secWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64ccmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cadsacisparaWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64ansysWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64voxelWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsansysWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgansysWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64solverWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64aasWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64dataDATA.GZ ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64apdlAPDL.GZ ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64geomparaWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgmechWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64autodynWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgautodynWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cfxWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgcfxWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configscfxWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64postWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cffWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluentcWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluentsWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluentaWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluentuWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluentpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluentmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluent2dWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluent2ddpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluent3dWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fluent3ddpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgfluentWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsfluentWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64distcompWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgcfdpostWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64aviewWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsaviewWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64spaceclmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsspaceclmWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64icemwbWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64electroWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64ecadxltrWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cadsspatialiopWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64cadsspatialWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64acpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addinsacpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsacpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64hlphlpviewerHLPVIEWER.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configshelpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64tpWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64tphdf5WINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64tpzlibWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64tpjreWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64chemkinWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configschemkinWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64forteWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64addincfgforteWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsforteWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64fensapWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsfensapWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64configsansconfigdllWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64studentWINX64.7z ...
      Extraction: C:UsersTanSoOneDriveDesktopANSYSACADEMICSTUDENT_2019R3_WINX64licenseWINX64.7z ...
      RSS is disabled
      Performing licensing configuration via the following command...
      "D:ANSYS IncShared Filesbinwinx64tclsh.exe" "D:ANSYS IncShared FilesLicensinglicadminscriptsLicAdminMain.itcl" -silentinstallclient -release "2019 R3" -lang en-us
      Licensing configuration has completed.
      Running D:ANSYS Incv195commonfilesconfigswinx64configAnsConfigCommon.exe
      Configuring ANSYS TurboGrid ...
      Running D:ANSYS Incv195commonfilesconfigswinx64configAnsConfigTG.exe
      Creating Start menu items for ANSYS client licensing ...
      Running D:ANSYS Incv195commonfilesconfigswinx64configAnsConfigWB.exe
      Running D:ANSYS Incv195FrameworkbinWin64Ans.DriverSetup.exe
      Failed to add/update profile.
      Running "D:ANSYS Incv195RSMbinAnsConfigRSM.exe" -encodingUTF8
      Configuring RSM...
      Configuring default RSM and ARC Port numbers for 2019 R3 ...
      Done!
      User has Administrator privileges
      Creating Start Menu Shortcut for RSM 2019 R3 Configuration...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Configuration 2019 R3.lnk
      Creating Start Menu Shortcut for RSM 2019 R3 Job Monitor...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Job Monitoring 2019 R3.lnk
      Creating Start Menu Shortcut for RSM 2019 R3 Cluster Monitor...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Cluster Monitoring 2019 R3.lnk
      Creating Start Menu Shortcut for ARC 2019 R3 Configuration...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerARC Configuration 2019 R3.lnk
      Running D:ANSYS Incv195commonfilesconfigswinx64configAnsConfigANSYS.exe
      Adding write permissions for Users and Administrators group ...
      Running D:ANSYS Incv195commonfilesconfigswinx64configAnsConfigCFX.exe
      Configuring ANSYS Viewer ...
    • SSTan
      And when I uninstall, the software stuck at this
      Extraction: D:ANSYS Incv195installerinstcoretclCOMMON.TGZ ...
      Extraction: D:ANSYS Incv195installerinstcoretclWINX64.TGZ ...
      Processing selections for uninstall ...
      Attempting to terminate running processes whose images will be removed ...
      Successfully unregistered DLLs...
      Running "D:ANSYS Incv195aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe" -unconfigure
      Log files is D:ANSYS Incv195CADConfigLogsLatestCADConfigurationMgr.log
      MessageLogger.logFilePath is D:ANSYS Incv195CADConfigLogsLatestCADConfigurationMgr.log
      ErrorLogger.errorFilePath is D:ANSYS Incv195CADConfigLogsCADConfigurationMgr.err
      Prerequisites ..... Unconfigure Success
      Running D:ANSYS Incv195commonfilesconfigswinx64unconfigAnsUnconfigCommon.exe
      Unconfiguring ANSYS TurboGrid ...
      Running D:ANSYS Incv195commonfilesconfigswinx64unconfigAnsUnconfigTG.exe
      Running D:ANSYS Incv195commonfilesconfigswinx64unconfigAnsUnconfigWB.exe
      Running "D:ANSYS Incv195RSMbinAnsUnconfigRSM.exe" -encodingUTF8
      Unconfiguring RSM...
      Removing Start Menu Shortcut for RSM Configuration ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Configuration 2019 R3.lnk
      Removing Start Menu Shortcut for RSM Job Monitoring ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Job Monitoring 2019 R3.lnk
      Removing Start Menu Shortcut for RSM Cluster Monitoring ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Cluster Monitoring 2019 R3.lnk
      Removing Start Menu Shortcut for ARC Configuration ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerARC Configuration 2019 R3.lnk
      Deleted Shortcut Folder C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve Manager
      Running D:ANSYS Incv195commonfilesconfigswinx64unconfigAnsUnconfigANSYS.exe
      Running D:ANSYS Incv195commonfilesconfigswinx64unconfigAnsUnconfigCFX.exe
      Unconfiguring ANSYS Viewer ...
    • joanro4
      Did you fix this?
      I have the same exact problem and i don't have any clue on what to do...
    • Sean Bradley
      Were you ever able to fix this issue?
Viewing 4 reply threads
  • The topic ‘Issue – installer stuck at 96%, at Configuring ANSYS Viewer’ is closed to new replies.
