LS Dyna
LS Dyna
Isogeometric analysis
    • Nikhil Khaire
      Hello Team,
      This is Nikhil Khaire, currently, I am exploring the Iso geometric analysis (IGA) capabilities available in the LS prepost.
      For the initial stage, I have started with the 3pt bend analysis. The 2- hollow rectangular (see Fig1)beam was used for test case.  With available capabilities in the ls prepost, I have created the set up. However, I am facing issue with Connection at the T- joint.
      While creating the mesh I used the build contact option which generates the Contact ( Nurbs tied_edge to edge) and also generate the IGA keyword Tied edge to edge (see  fig.2).
      The followings problem I am facing while running it.
      1. when I launched the job the, it get error out with message “ The Nurbs tied_edge to edge is not a valid Keyword)
      2. I removed the keywords from the file and re run and job completed with normal termination. However, at the start there was a  warning (see fig.3)
      3. When I checked the simulation results there was no connection of the middle wall (see Fig 4)
      I used smp_s_R13_0. SOLVER to launch the run.
      Please kindly provide any suggestion to resolve this issue.
    • ashish.khemka
      Hello Nikhil,
      I am not an expert in this area but please see if the following link helps:
      6.8. Merge Element Edge (ansys.com)
      Ashish Khemka
    • Nikhil Khaire
      Hello Ashish,
      Thank you for your reply. I have tried merge edge option. However, It is not working.It is possible to get help from someone who is expert in this field?
