August 3, 2021 at 8:39 pm
DaN
SubscriberHello everyone,
I simulate gas-phase-reactions in a flow field within a tube using Fluent, DPM (with UDF for absorption) and chemkin import.
The simulation is apparently on its way to convergence, but during the iterations with this message is written:
********** ISAT_ABORT **************
routine = phi2y
location = 1
message = non-positive species sum
****** END ISAT_ABORT **************
The iterations take much more time .
How can I indefinite the cause of this? I guess it is about some insufficient thermodynamic properties.
Thank you for your help.
August 4, 2021 at 3:15 pmRK
Ansys EmployeeHello,
Probably the time step is too large for the chemical kinetics. Can you reduce it by 2 or 3 orders of magnitude and try again?
If the issue still persists after lowering the time step, I would assume the issue is with the ISAT table. You can back track to a point before the error occurred, clear the ISAT table and continue with calculation.
Viewing 1 reply thread- The topic ‘ISAT_ABORT’ is closed to new replies.
2984
970
857
755
599
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
