September 3, 2024 at 2:23 am
kangjs1420
SubscriberHello
I'm a student studying welding engineering.
I'm going to use ANSYS to do fatigue analysis.
I have thermo-mechanical analysis data that previously analyzed the welding process with other software(Hexagon Simufact).
The extension of the data file is bdf, and I would like to bring the residual stress data stored inside the file to ANSYS for fatigue analysis.
I'd appreciate it if you could tell me how
September 3, 2024 at 3:06 pm
Nanda
Ansys EmployeeHello Kang,
Yes, it is possible to bulk data file(*.bdf) into Ansys for your fatigue analysis. Please refer to the below steps:- In the BDF (Bulk Data File) format you mentioned, please ensure the data includes each node’s stress tensor components (Sxx, Syy, Szz, Sxy, Sxz, Syz) before you export it.
- In ANSYS Workbench, create a new Static Structural analysis system.
- Import the geometry of your welded part into the Static Structural system.
- Right-click on the Geometry cell and select “Import Geometry”. Browse to the BDF file exported from Simufact and import it.
- ANSYS will read the residual stress data from the BDF file and map it onto the imported geometry. The stress tensor components will be available as solution data.
- This solution data can be mapped to your fatigue analysis module
For more details, please refer to these links:
Importing Files (ansys.com)
WB import entire Nastran model .bdf (ansys.com)Regards,
Nanda.
If you are not able to open Ansys help links, refer to this forum discussion: How to access the ANSYS Online Help
Also, we launched a public help documentation website: Ansys Help
For more exciting courses and certifications, hit this link: Ansys Innovation Courses | Ansys Innovation Space
- BackGround Color
- Contact stiffness too big
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
- Which equations and in what form are valid for defining excitations?
4597
1495
1386
1209
