March 7, 2026 at 9:24 pm
trytobeanas
SubscriberHi,
I have a question regarding the correct setup for calculating wall deformation caused by fluid pressure in ANSYS.
In my case, fluid pressure from a CFD simulation is applied on the pipe wall, and I want to evaluate the resulting structural deformation of the wall.
My question is:
Is it necessary to explicitly define and mesh the solid domain in order to compute the wall deformation, or is there a way to obtain the deformation without creating a full solid mesh?As a preliminary step, I am planning to test this using a simple pipe model and perform structural analysis based on the fluid pressure distribution.
I would appreciate any guidance on the recommended modeling approach or best practices for this type of problem.
Thank you for your help.
March 16, 2026 at 2:58 pm
Federico
Ansys EmployeeHello,
yes, you will need to include the solid mesh to perform a structural analysis. You can do it within Fluent itself, look at intrinsinc FSI Chapter 29: Modeling Fluid-Structure Interaction (FSI) Within Fluent
6039
