Ansys Products
Ansys Products
Is ModelCenter MBSE compatible with Magic Systems of Systems Architect?
    • mmrhoade
      Version 14 of ModelCenter MBSE was not compatible with Magic Systems of Systems Architect (MSOSA), a MagicDraw based product made by 3DS that is being offered to academic universities at a much lower price than Cameo Enterprise Architecture.   There was talk about making it compatible in the future.   Does anyone know if ModelCenter MBSE is compatible with MSOSA version 2022X with the Magic Model Analyst plug-in?
    • Ashish Khemka
      Hi Mark,
      I am not sure. Can you please check ti here: Magic Systems of Systems Architect Documentation (nomagic.com)
      Regrds,
      Ashish Khemka
    • Fernando Saca
      I am trying to connect MSOSA as well and get an error where the plugin is looking for MagicDraw specifically and its associated JRE. I was told that it would eventually support it but it has now been a couple of years, are there any updates when we can expect this support?
    • Carl Barbour
      Support for MagicDraw/Cameo 2022x was added in ModelCenter 2023 R1.
      MagicDraw, Cameo Enterprise Architecture, and Cameo Systems Modeler are officially supported.
      The ModelCenter MBSE Plug-In can be installed to MSOSA and will work when opened from the Tools drop-down menu in MSOSA.  When installing the ModelCenter MBSE Connector for MagicDraw, choose Custom sa the install type if prompted.  On the Custom Setup screen, select the second option for "MagicDraw Installation Location".  Click the Browse button in the lower right, and select the folder where MSOSA is installed on your system.  The ModelCenter MBSE Plug-In will be installed and available in the MSOSA Tools drop-down menu.
    • Fernando Saca
      That works, thank you!
Viewing 4 reply threads
  • The topic ‘Is ModelCenter MBSE compatible with Magic Systems of Systems Architect?’ is closed to new replies.
