June 25, 2020 at 10:24 am
tayyaba.bano
SubscriberHi everyone,
with reference to the attached video, is the command used for LES model (rpsetvar 'les-2d? #t) same for both 3d and 2d or should it be
(rpsetvar 'les-3d? #t)Â for 3d? because when I do this for my 3d case,it states:Undefined variable
https://www.youtube.com/watch?v=wAoXIyVOY9E
waiting for your kind response.
Tayyaba
June 25, 2020 at 11:42 am
DrAmine
Ansys EmployeeLES is actually only 3D and that is the default behavior. You do not need to activate any hidden flag. 2D LES is just a "goodie" and not recommended and I will say is not as one would expect from real LES.
June 30, 2020 at 10:00 am
tayyaba.bano
SubscriberThank you very much for your kind reply. It means it is just a default laminar simulation.
Regards
Tayyaba
June 30, 2020 at 12:23 pm
DrAmine
Ansys EmployeeNot really understand your question. What do you mean?
July 1, 2020 at 9:00 am
tayyaba.bano
SubscriberI mean the default setting of Fluent is for LES, there is no need to activate it by any command.
Regards
Tayyaba
July 1, 2020 at 2:30 pm
Forum ModeratorYou can turn LES turbulence on in the viscous models panel. Fluent defaults to laminar or k-omega depending on which version you're using.Â
July 1, 2020 at 2:55 pm
DrAmine
Ansys EmployeeRead Mesh, Switch LES, EnJoY!
July 2, 2020 at 10:21 am
July 2, 2020 at 12:32 pm
DrAmine
Ansys EmployeeMark as "Is Solved".
- The topic ‘Is it possible to have a 3d LES simulation by using Fluent’ is closed to new replies.
5824
