November 12, 2020 at 6:51 am
boonthiam13
SubscriberHi, I want to observe thermal residual stress developed near to surface of a thermoplastic due to change in temperature, is ANSYS providing such a capability?nThanks in advance n -
November 13, 2020 at 7:44 pm
SaiD
Ansys EmployeeHi,nDo you know the temperature distribution over the body? One thing to try would be to perform a Steady-state thermal analysis or a Transient Thermal analysis to get the temperature distribution. Then create a Static Structural analysis and connect the Results cell of thermal analysis to Setup cell of structural analysis. This will import the temperature distribution from the thermal analysis to the structural analysis. nIf relevant material properties are defined in the structural analysis (i.e. coefficient of thermal expansion, plasticity model etc.) then you should be able to get the thermal residual stresses.nnHope this helps,nSain
- The topic ‘Is ANSYS capable to model thermal residual stress?’ is closed to new replies.
