January 14, 2024 at 12:18 pm
Casaf Yoseph
SubscriberHi Folks! Is there a way to scroll up and zoom in and scroll down and zoom out in HFSS? It is inverted by default...
Thx -
January 22, 2024 at 4:40 am
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum, your patience is much appreciated.
Please let us know the version of AEDT that you are using to help us serve you better.Â
Best regards,
Praneeth.-
February 27, 2024 at 4:24 pm
Stephan
SubscriberÂ
Hi, I’m having the same issue too. I am using version 2024R1.Â
The strange thing is I don’t have such issue with 2022R1 version.
February 28, 2024 at 8:23 am
Praneeth
Ansys EmployeeHi,
Please note that this is not an issue, but it is an intended change in 2024R1 to make the behavior of AEDT consistent with other Ansys products.
Best regards,
Praneeth Munaga.-
March 1, 2024 at 6:59 pm
Stephan
SubscriberHi, thank you for the response. Is it possible to revert this behaviour? I could not find a way in the settings.
March 4, 2024 at 1:21 am
daiki.anan
SubscriberI have the same problem.
This zoom operate is also inconsistent with "alt + shift + drag" zoom. -
March 4, 2024 at 9:42 pm
Daniel Hyman
SubscriberI can only assume that some fresh-off-the-frat-house-minted Harvard MBA just proposed to invert the commands and assumed that "engineers will just learn to adapt". Some of us have been using HFSS longer than said MBA has been alive, and we don't appreciate having to unlearn a lifetime of muscle memory. Literally every polygon pushing program permits inversion of this input device. Is there a back-door command we can use to undo Alpha Beta Chet's decision and fix AED 2024?
March 5, 2024 at 5:45 am
Praneeth
Ansys EmployeeThe users will have the option to select the mouse zoom option by the 2024R1 patch. The patch is not released yet. Unfortunately, the mouse zoom inversion option is not available in 2024 R1.Â
March 5, 2024 at 6:00 pm
Daniel Hyman
SubscriberGreat to know people are looking into the fix, thank you Praneeth! Can you please ensure a post enters this thread when the patch is released? Much appreciated so we get the alert ASAP and for future users to find the solution easily, as this thread is highly ranked on both Google and DuckDuckGo. Thanks!
March 6, 2024 at 4:48 am
Praneeth
Ansys EmployeeThanks for your reply, Daniel. Will update you after the release of the patch for 2024 R1.
May 14, 2024 at 4:55 am
Praneeth
Ansys EmployeeHi,
Please note that patch for 2024 R1 is released and is available for download in the Ansys customer portal.Â
For detailed information, please go through the release notes.
Best regards,
Praneeth.
- The topic ‘Invert mouse zoom axis in HFSS ANSYS’ is closed to new replies.
6374
