June 8, 2020 at 8:13 am
AmirulHaziq
SubscriberHi
I am using Ansys Workbench to calculate the number of cycles till failure for an ankle implant made of CoCrMo and UHMWPE parts. The model is subjected to a 796 N load pointing upwards. I've added the material properties of isotropic elasticity, Young's Modulus, Poisson's Ratio, Ultimate tensile strength and tensile yield strength. However, once I have solved, I get the error- "Invalid or missing stress life curve". Just what exactly am I missing or which parameter is wrong? Any help will be appreciated.
June 8, 2020 at 1:09 pm
Sai Deogekar
Ansys EmployeeHi,
Can you check the Materials properties in Mechanical and make sure the S-N curve has been defined? The following post might help:
/forum/forums/topic/fatigue-random-vibration-analysis-error-with-stress-life-curve/
Sai
June 15, 2020 at 11:01 am
AmirulHaziq
SubscriberYes it works.thank you
- The topic ‘Invalid/missing Stress Life curve’ is closed to new replies.
6495
