January 9, 2025 at 10:45 am
martijnschrama298
SubscriberDear,
Im working on a project and want to use Ansys to make a simulation (ultimately force-deflection graph). I made a mock of this assembly, which I imported and turned out fine, there were no errors. However, after importing the real part I do have an error: Invalid "Boundary Condition". I do not understand where this comes from as i used a fixed support for one surface, and only apply one load on it. Is there anyone who can help troubleshoot?
Thanks in advance
M. Schrama -
January 9, 2025 at 12:45 pm
Aniket Chavan
Forum Moderatorcan you right click on error and go to object? Also there seems a question mark on static structural solution folder, please expand it and see which object has that.
-Aniket
January 11, 2025 at 12:15 pm
peteroznewman
SubscriberFollow Aniket’s advice and post the answer.
To get an accurate force-deflection curve, turn on Large Deflection under Analysis Settings. To make sure you get at least 20 points along the curve, under Analysis Settings, turn on Auto TIme Stepping then under the Initial and Minimum Substeps, use 20 and for Maximum Substeps, use 200.
Please post the curve for my interest.
Thanks.
January 13, 2025 at 11:48 am
martijnschrama298
SubscriberHi all,
Thanks for the help. In the end we wanted a hinge at the top, and also decided to clean up the model in solidworks. For giving it a displacement the model works, which is enough for the project. Added is a screenshot of the model and plot. Large deflection is on. The model doesn't like when a force is added yet, which makes me curious why, but thanks already!
January 5, 2026 at 6:55 am
324203307006
SubscriberHi,
I am performing a nonlinear buckling analysis on a I-section. During the simulation, I am getting this error - "The solver engine was unable to converge on a solution for the nonlinear problem." I already tried increasing the number of substeps but it didnot work. Could someone please help me resolve this error.
I am also attaching the solution information for further reference,
Thank you in advance
ANSYS Mechanical Enterprise
| W E L C O M E T O T H E A N S Y S (R) P R O G R A M |
* ANSYS 2019 R3 LEGAL NOTICES *
* Copyright 1971-2019 ANSYS, Inc. All rights reserved. *
* Unauthorized use, distribution or duplication is *
* prohibited.*
* Ansys is a registered trademark of ANSYS, Inc. or its *
* subsidiaries in the United States or other countries. *
* See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
* documentation CD or online help for the complete Legal *
* Notice.*
* THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION *
* INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY *
* PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS. *
* The software products and documentation are furnished by *
* ANSYS, Inc. or its subsidiaries under a software license *
* agreement that contains provisions concerning *
* non-disclosure, copying, length and nature of use, *
* compliance with exporting laws, warranties, disclaimers, *
* limitations of liability, and remedies, and other *
* provisions. The software products and documentation may be *
* used, disclosed, transferred, or copied only in accordance *
* with the terms and conditions of that software license *
* agreement.*
* ANSYS, Inc. is a UL registered*
* ISO 9001:2015 company.*
* This product is subject to U.S. laws governing export and *
* re-export.*
* For U.S. Government users, except as specifically granted *
* by the ANSYS, Inc. software license agreement, the use, *
* duplication, or disclosure by the United States Government *
* is subject to restrictions stated in the ANSYS, Inc. *
* software license agreement and FAR 12.212 (for non-DOD *
* licenses).*
2019 R3
Point Releases and Patches installed:
ANSYS, Inc. Products 2019 R3
SpaceClaim 2019 R3
AIM 2019 R3
Live (includes SpaceClaim) 2019 R3
Autodyn 2019 R3
LS-DYNA 2019 R3
CFX (includes CFD-Post) 2019 R3
Chemkin 2019 R3
EnSight 2019 R3
FENSAP-ICE 2019 R3
Fluent (includes CFD-Post) 2019 R3
Forte 2019 R3
Polyflow (includes CFD-Post) 2019 R3
TurboGrid 2019 R3
ICEM CFD 2019 R3
Aqwa 2019 R3
Mechanical Products 2019 R3
Additive 2019 R3
Icepak (includes CFD-Post) 2019 R3
ACIS Geometry Interface 2019 R3
AutoCAD Geometry Interface 2019 R3
Catia, Version 4 Geometry Interface 2019 R3
Catia, Version 6 Geometry Interface 2019 R3
Creo Elements/Direct Modeling Geometry Interface 2019 R3
Creo Parametric Geometry Interface 2019 R3
Inventor Geometry Interface 2019 R3
JTOpen Geometry Interface 2019 R3
NX Geometry Interface 2019 R3
Parasolid Geometry Interface 2019 R3
Solid Edge Geometry Interface 2019 R3
SOLIDWORKS Geometry Interface 2019 R3
ANSYS, Inc. License Manager 2019 R3
***** ANSYS COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
SHARED MEMORY PARALLEL REQUESTED
SINGLE PROCESS WITH 4 THREADS REQUESTED
TOTAL OF 4 CORES REQUESTED
INPUT FILE NAME = D:\2M\_ProjectScratch\ScrA65F\dummy.dat
OUTPUT FILE NAME = D:\2M\_ProjectScratch\ScrA65F\solve.out
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
RELEASE= 2019 R3 BUILD= 19.5 UP20190805 VERSION=WINDOWS x64
CURRENT JOBNAME=file 09:31:30 JAN 05, 2026 CP= 0.156
PARAMETER _DS_PROGRESS = 999.0000000
/INPUT FILE= ds.dat LINE= 0
DO NOT WRITE ELEMENT RESULTS INTO DATABASE
*GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 9.52500000
TITLE=
2M--Static Structural (C4)
SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
TYPE=STRI DIMENSIONS= 248 1 1
PARAMETER _WB_PROJECTSCRATCH_DIR(1) = D:\2M\_ProjectScratch\ScrA65F\
SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
PARAMETER _WB_SOLVERFILES_DIR(1) = D:\2M\2M_files\dp0\SYS-2\MECH\
SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
PARAMETER _WB_USERFILES_DIR(1) = D:\2M\2M_files\user_files\
--- Data in consistent NMM units. See Solving Units in the help system for more
MPA UNITS SPECIFIED FOR INTERNAL
LENGTH = MILLIMETERS (mm)
MASS = TONNE (Mg)
TIME = SECONDS (sec)
TEMPERATURE = CELSIUS (C)
TOFFSET = 273.0
FORCE = NEWTON (N)
HEAT = MILLIJOULES (mJ)
INPUT UNITS ARE ALSO SET TO MPA
*** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE 2019 R3 19.5 ***
20120530 VERSION=WINDOWS x64 09:31:30 JAN 05, 2026 CP= 0.219
***** ANSYS ANALYSIS DEFINITION (PREP7) *****
*********** Nodes for the whole assembly ***********
*********** Nodes for all Remote Points ***********
*********** Elements for Body 1 "SYS\Solid(Eigenvalue Buckling)" ***********
*********** Send User Defined Coordinate System(s) ***********
*********** Set Reference Temperature ***********
*********** Send Materials ***********
*********** Create Remote Point "Internal Remote Point" ***********
*********** Create Remote Point "Internal Remote Point 2" ***********
*********** Create Remote Point "Internal Remote Point 3" ***********
*********** Construct Remote Displacement ***********
*** Create a component for all remote displacements ***
LIST DATA TABLE BISO FOR MATERIAL 1
20120530 VERSION=WINDOWS x64 09:31:32 JAN 05, 2026 CP= 3.703
BiIso Pl (BISO) Table For Material 1
1
Temps 0.0000
Yld Strs 250.00
Tang Mod 2000.0
***** ROUTINE COMPLETED ***** CP = 3.703
--- Number of total nodes = 227921
--- Number of contact elements = 0
--- Number of spring elements = 0
--- Number of bearing elements = 0
--- Number of solid elements = 1080573
--- Number of condensed parts = 0
--- Number of total elements = 1080668
*GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 9.52555556
************************* SOLUTION ********************************
***** ANSYS SOLUTION ROUTINE *****
PERFORM A STATIC ANALYSIS
THIS WILL BE A NEW ANALYSIS
LARGE DEFORMATION ANALYSIS
PARAMETER _THICKRATIO = 1.000000000
USE SPARSE MATRIX DIRECT SOLVER
CONTACT INFORMATION PRINTOUT LEVEL 1
NLDIAG: Nonlinear diagnostics CONT option is set to ON.
Writing frequency : each ITERATION.
DEFINE RESTART CONTROL FOR LOADSTEP LAST
AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS 0
DELETE RESTART FILES OF ENDSTEP
******************* SOLVE FOR LS 1 OF 1 ****************
SPECIFIED CONSTRAINT UX FOR SELECTED NODES 227919 TO 227919 BY 1
REAL= 0.00000000 IMAG= 0.00000000
SPECIFIED CONSTRAINT UY FOR SELECTED NODES 227919 TO 227919 BY 1
SPECIFIED CONSTRAINT UZ FOR SELECTED NODES 227919 TO 227919 BY 1
SPECIFIED CONSTRAINT ROTZ FOR SELECTED NODES 227919 TO 227919 BY 1
SPECIFIED CONSTRAINT UX FOR SELECTED NODES 227920 TO 227920 BY 1
SPECIFIED CONSTRAINT UY FOR SELECTED NODES 227920 TO 227920 BY 1
SPECIFIED CONSTRAINT UZ FOR SELECTED NODES 227920 TO 227920 BY 1
SPECIFIED CONSTRAINT ROTZ FOR SELECTED NODES 227920 TO 227920 BY 1
SPECIFIED CONSTRAINT UX FOR SELECTED NODES 227921 TO 227921 BY 1
SPECIFIED CONSTRAINT UY FOR SELECTED NODES 227921 TO 227921 BY 1
REAL= -250.000000 IMAG= 0.00000000
SPECIFIED CONSTRAINT UZ FOR SELECTED NODES 227921 TO 227921 BY 1
SPECIFIED CONSTRAINT ROTZ FOR SELECTED NODES 227921 TO 227921 BY 1
PRINTOUT RESUMED BY /GOP
USE AUTOMATIC TIME STEPPING THIS LOAD STEP
USE 20 SUBSTEPS INITIALLY THIS LOAD STEP FOR ALL DEGREES OF FREEDOM
FOR AUTOMATIC TIME STEPPING:
USE 200 SUBSTEPS AS A MAXIMUM
USE 10 SUBSTEPS AS A MINIMUM
TIME= 1.0000
ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
FOR ALL APPLICABLE ENTITIES
WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE EANG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE ETMP ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE VENG ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
WRITE CONT ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
*GET ANSINTER_ FROM ACTI ITEM=INT VALUE= 0.00000000
*IF ANSINTER_( = 0.00000 ) NE
0( = 0.00000 ) THEN
*ENDIF
***** ANSYS SOLVE COMMAND *****
*** WARNING *** CP = 4.219 TIME= 09:31:32
Element shape checking is currently inactive. Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** NOTE *** CP = 5.922 TIME= 09:31:32
The model data was checked and warning messages were found.
Please review output or errors file (
D:\2M\_ProjectScratch\ScrA65F\file.err ) for these warning messages.
*** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
--- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
ELEMENT TYPE 1 IS SOLID285. NO SUGGESTION IS AVAILABLE AND NO RESETTING
IS NEEDED.
20120530 VERSION=WINDOWS x64 09:31:33 JAN 05, 2026 CP= 6.547
S O L U T I O N O P T I O N S
PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D
DEGREES OF FREEDOM. . . . . . UX UY UZ ROTX ROTY ROTZ HDSP
ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 273.15
NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE
PLASTIC MATERIAL PROPERTIES INCLUDED. . . . . .YES
NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN
GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRIC
*** NOTE *** CP = 7.141 TIME= 09:31:33
This nonlinear analysis defaults to using the full Newton-Raphson
solution procedure. This can be modified using the NROPT command.
The conditions for direct assembly have been met. No .emat or .erot
files will be produced.
*** NOTE *** CP = 8.438 TIME= 09:31:34
Internal nodes from 227922 to 227924 are created.
3 internal nodes are used for handling degrees of freedom on pilot
nodes of rigid target surfaces.
L O A D S T E P O P T I O N S
LOAD STEP NUMBER. . . . . . . . . . . . . . . . 1
TIME AT END OF THE LOAD STEP. . . . . . . . . . 1.0000
AUTOMATIC TIME STEPPING . . . . . . . . . . . . ON
INITIAL NUMBER OF SUBSTEPS . . . . . . . . . 20
MAXIMUM NUMBER OF SUBSTEPS . . . . . . . . . 200
MINIMUM NUMBER OF SUBSTEPS . . . . . . . . . 10
MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . . 15
STEP CHANGE BOUNDARY CONDITIONS . . . . . . . . NO
STRESS-STIFFENING . . . . . . . . . . . . . . . ON
TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)
CONVERGENCE CONTROLS. . . . . . . . . . . . . .USE DEFAULTS
COPY INTEGRATION POINT VALUES TO NODE . . . . .YES, FOR ELEMENTS WITH
ACTIVE MAT. NONLINEARITIES
PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
DATABASE OUTPUT CONTROLS
ITEM FREQUENCY COMPONENT
ALL NONE
NSOL ALL
RSOL ALL
EANG ALL
ETMP ALL
VENG ALL
STRS ALL
EPEL ALL
EPPL ALL
CONT ALL
SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr
*WARNING*: Some MPC/Lagrange based elements (e.g.1269155) in real
constant set 4 overlap with other MPC/Lagrange based elements
(e.g.1269200) in real constant set 6 which can cause overconstraint.
*** NOTE *** CP = 18.391 TIME= 09:31:37
Smoothing on certain contact nodes (e.g.199743) for pair ID 2 may have
accuracy issue. Please verify face normal of connected elements.
Smoothing on certain contact nodes (e.g.205739) for pair ID 2 may have
Smoothing on certain contact nodes (e.g.205740) for pair ID 2 may have
Smoothing on certain contact nodes (e.g.147565) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.147566) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.154663) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.154664) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.199801) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.199802) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.199805) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.199831) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.200036) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.200037) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.200043) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.220843) for pair ID 4 may have
Smoothing on certain contact nodes (e.g.4043) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.4049) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42464) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42472) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42477) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42482) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42522) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42523) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42531) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42535) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.42537) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.44666) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.44667) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.51824) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.67557) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.200043) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.200783) for pair ID 6 may have
*** NOTE *** CP = 18.406 TIME= 09:31:37
Smoothing on certain contact nodes (e.g.200791) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.200966) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.200997) for pair ID 6 may have
Smoothing on certain contact nodes (e.g.200998) for pair ID 6 may have
Force-distributed-surface identified by real constant set 2 and
contact element type 2 has been set up. The pilot node 227919 is used
to apply the force. Internal MPC will be built.
The used degrees of freedom set is UX UY UZ ROTX ROTY ROTZ
Please verify constraints (including rotational degrees of freedom)
on the pilot node by yourself.
Force-distributed-surface identified by real constant set 4 and
contact element type 4 has been set up. The pilot node 227920 is used
*WARNING*: Certain contact elements (for example 1269155&1269200)
overlap each other.
Force-distributed-surface identified by real constant set 6 and
contact element type 6 has been set up. The pilot node 227921 is used
*WARNING*: Certain contact elements (for example 1269200&1269155)
overlap each other.
*** WARNING *** CP = 18.406 TIME= 09:31:37
Overconstraint may occur for Lagrange multiplier or MPC based contact
algorithm.
The reasons for possible overconstraint are:
Certain contact elements (for example 1269200 & 1269155) overlap with
other.
MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS HAS BEEN MODIFIED
TO BE, NEQIT = 25, BY SOLUTION CONTROL LOGIC.
*** NOTE *** CP = 18.438 TIME= 09:31:37
*** NOTE *** CP = 19.281 TIME= 09:31:38
The initial memory allocation (-m) has been exceeded.
Supplemental memory allocations are being used.
The FEA model contains 0 external CE equations and 18 internal CE
equations.
*********** PRECISE MASS SUMMARY ***********
TOTAL RIGID BODY MASS MATRIX ABOUT ORIGIN
Translational mass | Coupled translational/rotational mass
0.36565E-01 0.0000 0.0000 | 0.0000 -9.1412 -2.7444
0.0000 0.36565E-01 0.0000 | 9.1412 0.0000 0.18121E-02
0.0000 0.0000 0.36565E-01 | 2.7444 -0.18121E-02 0.0000
| Rotational mass (inertia)
| 21674. -0.17120 0.45267
| -0.17120 21339. 686.11
| 0.45267 686.11 354.15
TOTAL MASS = 0.36565E-01
The mass principal axes coincide with the global Cartesian axes
CENTER OF MASS (X,Y,Z)= 0.49559E-01 75.057 -250.00
TOTAL INERTIA ABOUT CENTER OF MASS
19183. -0.35190E-01 -0.35591E-03
-0.35190E-01 19054. -0.84405E-04
-0.35591E-03 -0.84405E-04 148.16
The inertia principal axes coincide with the global Cartesian axes
*** MASS SUMMARY BY ELEMENT TYPE ***
TYPE MASS
1 0.365646E-01
Range of element maximum matrix coefficients in global coordinates
Maximum = 584630.428 at element 89538.
Minimum = 35351.3383 at element 373239.
*** ELEMENT MATRIX FORMULATION TIMES
TYPE NUMBER ENAME TOTAL CP AVE CP
1 1080573 SOLID285 246.469 0.000228
2 5 CONTA175 0.000 0.000000
3 1 TARGE170 0.000 0.000000
4 32 CONTA175 0.000 0.000000
5 1 TARGE170 0.000 0.000000
6 55 CONTA175 0.000 0.000000
7 1 TARGE170 0.000 0.000000
Time at end of element matrix formulation CP = 83.1875.
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.rdb
FOR POSSIBLE RESUME FROM THIS POINT
FORCE CONVERGENCE VALUE = 0.000 CRITERION= 0.5102E-04
VOLUME CONVERGENCE VALUE = 0.000 CRITERION= 1.320
SPARSE MATRIX DIRECT SOLVER.
Number of equations = 911660, Maximum wavefront = 434
Memory allocated for solver = 6228.765 MB
Memory required for in-core solution = 4486.362 MB
Memory required for out-of-core solution = 884.244 MB
*** NOTE *** CP = 88.906 TIME= 09:32:00
The Sparse Matrix Solver is currently running in the in-core memory
mode. This memory mode uses the most amount of memory in order to
avoid using the hard drive as much as possible, which most often
results in the fastest solution time. This mode is recommended if
enough physical memory is present to accommodate all of the solver
data.
*** WARNING *** CP = 88.906 TIME= 09:32:00
Pivoting has been activated for the Sparse Matrix Solver . The memory
required may greatly exceed the predicted amount. In that event, use
the DSPOPTION command to change the memory mode and/or memory size
used by the Sparse Matrix Solver.
curEqn= 911638 totEqn= 911660 Job CP sec= 112.219
Factor Done= 99% Factor Wall sec= 0.000 rate= 0.0 Mflops
curEqn= 911660 totEqn= 911660 Job CP sec= 112.406
Factor Done= 100% Factor Wall sec= 0.052 rate= 8894537.1 Mflops
Sparse solver maximum pivot= 4570329.2 at node 227659 UX.
Sparse solver minimum pivot= 23.6986412 at node 212766 UX.
Sparse solver minimum pivot in absolute value= 23.6986412 at node
212766 UX.
DISP CONVERGENCE VALUE = 12.60 CRITERION= 0.6426
HDSP CONVERGENCE VALUE = 1129. CRITERION= 56.44
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -12.60
DISP CONVERGENCE VALUE = 12.60 CRITERION= 0.6557
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -12.60
3 FORCE-DISTRIBUTED CONSTRAINTS DO NOT SATISFY COMPATIBILITY CONDITION
FORCE CONVERGENCE VALUE = 1338. CRITERION= 11.87
VOLUME CONVERGENCE VALUE = 0.3922E-02 CRITERION= 1.347 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -4.178
DISP CONVERGENCE VALUE = 4.178 CRITERION= 0.6708
HDSP CONVERGENCE VALUE = 776.6 CRITERION= 80.15
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -4.178
FORCE CONVERGENCE VALUE = 3747. CRITERION= 35.43
VOLUME CONVERGENCE VALUE = 0.6922E-01 CRITERION= 1.375 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 1.388
DISP CONVERGENCE VALUE = 1.388 CRITERION= 0.6845
HDSP CONVERGENCE VALUE = 532.9 CRITERION= 80.15
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 1.388
2 FORCE-DISTRIBUTED CONSTRAINTS DO NOT SATISFY COMPATIBILITY CONDITION
FORCE CONVERGENCE VALUE = 1676. CRITERION= 3.229
VOLUME CONVERGENCE VALUE = 0.2001E-01 CRITERION= 1.403 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 1.053
DISP CONVERGENCE VALUE = 0.7559 CRITERION= 0.6984
HDSP CONVERGENCE VALUE = 273.4 CRITERION= 80.15
LINE SEARCH PARAMETER = 0.7182 SCALED MAX DOF INC = 0.7559
FORCE CONVERGENCE VALUE = 1079. CRITERION= 6.867
VOLUME CONVERGENCE VALUE = 0.4581E-01 CRITERION= 1.431 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7646
DISP CONVERGENCE VALUE = 0.3823E-01 CRITERION= 0.7127 <<< CONVERGED
HDSP CONVERGENCE VALUE = 34.64 CRITERION= 80.15 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.3823E-01
FORCE CONVERGENCE VALUE = 1052. CRITERION= 6.915
VOLUME CONVERGENCE VALUE = 0.1823E-01 CRITERION= 1.460 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7184
DISP CONVERGENCE VALUE = 0.7184 CRITERION= 0.7315 <<< CONVERGED
HDSP CONVERGENCE VALUE = 450.9 CRITERION= 80.83
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.7184
FORCE CONVERGENCE VALUE = 854.8 CRITERION= 9.371
VOLUME CONVERGENCE VALUE = 0.7193E-01 CRITERION= 1.490 <<< CONVERGED
EQUIL ITER 7 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4273
DISP CONVERGENCE VALUE = 0.7851E-01 CRITERION= 0.7479 <<< CONVERGED
HDSP CONVERGENCE VALUE = 143.2 CRITERION= 81.14
LINE SEARCH PARAMETER = 0.1838 SCALED MAX DOF INC = 0.7851E-01
FORCE CONVERGENCE VALUE = 730.8 CRITERION= 8.810
VOLUME CONVERGENCE VALUE = 0.4417E-01 CRITERION= 1.521 <<< CONVERGED
EQUIL ITER 8 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4249
DISP CONVERGENCE VALUE = 0.2125E-01 CRITERION= 0.7635 <<< CONVERGED
HDSP CONVERGENCE VALUE = 26.52 CRITERION= 81.40 <<< CONVERGED
LINE SEARCH PARAMETER = 0.5000E-01 SCALED MAX DOF INC = 0.2125E-01
FORCE CONVERGENCE VALUE = 753.0 CRITERION= 8.854
VOLUME CONVERGENCE VALUE = 0.6993E-02 CRITERION= 1.552 <<< CONVERGED
EQUIL ITER 9 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4135
DISP CONVERGENCE VALUE = 0.4135 CRITERION= 0.7876 <<< CONVERGED
HDSP CONVERGENCE VALUE = 232.3 CRITERION= 89.34
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.4135
FORCE CONVERGENCE VALUE = 458.1 CRITERION= 7.621
VOLUME CONVERGENCE VALUE = 0.6135E-01 CRITERION= 1.583 <<< CONVERGED
EQUIL ITER 10 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1503
DISP CONVERGENCE VALUE = 0.1713E-01 CRITERION= 0.8047 <<< CONVERGED
HDSP CONVERGENCE VALUE = 69.29 CRITERION= 90.27 <<< CONVERGED
LINE SEARCH PARAMETER = 0.1140 SCALED MAX DOF INC = -0.1713E-01
FORCE CONVERGENCE VALUE = 502.2 CRITERION= 15.61
VOLUME CONVERGENCE VALUE = 0.1877E-02 CRITERION= 3.231 <<< CONVERGED
EQUIL ITER 11 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1391
DISP CONVERGENCE VALUE = 0.1391 CRITERION= 0.8297 <<< CONVERGED
HDSP CONVERGENCE VALUE = 205.4 CRITERION= 97.18
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.1391
FORCE CONVERGENCE VALUE = 330.8 CRITERION= 8.110
VOLUME CONVERGENCE VALUE = 0.1810E-02 CRITERION= 1.649 <<< CONVERGED
EQUIL ITER 12 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3493
DISP CONVERGENCE VALUE = 0.3493 CRITERION= 0.8530 <<< CONVERGED
HDSP CONVERGENCE VALUE = 166.7 CRITERION= 103.2
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.3493
FORCE CONVERGENCE VALUE = 327.1 CRITERION= 8.249
VOLUME CONVERGENCE VALUE = 0.2130E-02 CRITERION= 1.682 <<< CONVERGED
EQUIL ITER 13 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6853
DISP CONVERGENCE VALUE = 0.6853 CRITERION= 0.8753 <<< CONVERGED
HDSP CONVERGENCE VALUE = 165.0 CRITERION= 108.8
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.6853
FORCE CONVERGENCE VALUE = 323.2 CRITERION= 8.416
VOLUME CONVERGENCE VALUE = 0.3219E-02 CRITERION= 1.717 <<< CONVERGED
EQUIL ITER 14 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7498
DISP CONVERGENCE VALUE = 0.7498 CRITERION= 0.8978 <<< CONVERGED
HDSP CONVERGENCE VALUE = 171.0 CRITERION= 114.1
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.7498
FORCE CONVERGENCE VALUE = 311.7 CRITERION= 8.631
VOLUME CONVERGENCE VALUE = 0.3442E-02 CRITERION= 1.752 <<< CONVERGED
EQUIL ITER 15 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5645
DISP CONVERGENCE VALUE = 0.5645 CRITERION= 0.9217 <<< CONVERGED
HDSP CONVERGENCE VALUE = 161.9 CRITERION= 118.8
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5645
FORCE CONVERGENCE VALUE = 277.3 CRITERION= 9.093
VOLUME CONVERGENCE VALUE = 0.2799E-02 CRITERION= 1.787 <<< CONVERGED
EQUIL ITER 16 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3220
DISP CONVERGENCE VALUE = 0.3220 CRITERION= 0.9469 <<< CONVERGED
HDSP CONVERGENCE VALUE = 140.2 CRITERION= 122.9
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.3220
FORCE CONVERGENCE VALUE = 257.0 CRITERION= 9.545
VOLUME CONVERGENCE VALUE = 0.2735E-02 CRITERION= 1.824 <<< CONVERGED
EQUIL ITER 17 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.3816
DISP CONVERGENCE VALUE = 0.3816 CRITERION= 0.9717 <<< CONVERGED
HDSP CONVERGENCE VALUE = 126.6 CRITERION= 126.6
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.3816
FORCE CONVERGENCE VALUE = 224.9 CRITERION= 9.806
VOLUME CONVERGENCE VALUE = 0.2861E-02 CRITERION= 1.861 <<< CONVERGED
EQUIL ITER 18 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5334
DISP CONVERGENCE VALUE = 0.5334 CRITERION= 0.9962 <<< CONVERGED
HDSP CONVERGENCE VALUE = 118.6 CRITERION= 130.2 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5334
FORCE CONVERGENCE VALUE = 217.0 CRITERION= 20.11
VOLUME CONVERGENCE VALUE = 0.3105E-02 CRITERION= 3.798 <<< CONVERGED
EQUIL ITER 19 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5941
DISP CONVERGENCE VALUE = 0.5941 CRITERION= 1.021 <<< CONVERGED
HDSP CONVERGENCE VALUE = 113.3 CRITERION= 133.6 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5941
FORCE CONVERGENCE VALUE = 202.5 CRITERION= 20.55
VOLUME CONVERGENCE VALUE = 0.3248E-02 CRITERION= 3.876 <<< CONVERGED
EQUIL ITER 20 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5674
DISP CONVERGENCE VALUE = 0.5674 CRITERION= 1.046 <<< CONVERGED
HDSP CONVERGENCE VALUE = 109.5 CRITERION= 137.0 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5674
FORCE CONVERGENCE VALUE = 199.0 CRITERION= 21.07
VOLUME CONVERGENCE VALUE = 0.3306E-02 CRITERION= 3.955 <<< CONVERGED
EQUIL ITER 21 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5336
DISP CONVERGENCE VALUE = 0.5263 CRITERION= 1.073 <<< CONVERGED
HDSP CONVERGENCE VALUE = 103.8 CRITERION= 140.2 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9864 SCALED MAX DOF INC = 0.5263
FORCE CONVERGENCE VALUE = 196.7 CRITERION= 21.89
VOLUME CONVERGENCE VALUE = 0.3356E-02 CRITERION= 4.035 <<< CONVERGED
EQUIL ITER 22 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5230
DISP CONVERGENCE VALUE = 0.5041 CRITERION= 1.099 <<< CONVERGED
HDSP CONVERGENCE VALUE = 97.59 CRITERION= 143.2 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9640 SCALED MAX DOF INC = 0.5041
FORCE CONVERGENCE VALUE = 188.4 CRITERION= 22.39
VOLUME CONVERGENCE VALUE = 0.3424E-02 CRITERION= 4.118 <<< CONVERGED
EQUIL ITER 23 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5279
DISP CONVERGENCE VALUE = 0.5020 CRITERION= 1.126 <<< CONVERGED
HDSP CONVERGENCE VALUE = 94.18 CRITERION= 146.2 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9509 SCALED MAX DOF INC = 0.5020
FORCE CONVERGENCE VALUE = 187.0 CRITERION= 22.96
VOLUME CONVERGENCE VALUE = 0.3523E-02 CRITERION= 4.202 <<< CONVERGED
EQUIL ITER 24 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5253
DISP CONVERGENCE VALUE = 0.4939 CRITERION= 1.154 <<< CONVERGED
HDSP CONVERGENCE VALUE = 89.86 CRITERION= 149.2 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9402 SCALED MAX DOF INC = 0.4939
FORCE CONVERGENCE VALUE = 186.5 CRITERION= 23.52
VOLUME CONVERGENCE VALUE = 0.3622E-02 CRITERION= 4.288 <<< CONVERGED
EQUIL ITER 25 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5208
DISP CONVERGENCE VALUE = 0.4888 CRITERION= 1.159 <<< CONVERGED
HDSP CONVERGENCE VALUE = 87.21 CRITERION= 152.1 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9387 SCALED MAX DOF INC = 0.4888
FORCE CONVERGENCE VALUE = 171.8 CRITERION= 21.60
VOLUME CONVERGENCE VALUE = 0.3728E-02 CRITERION= 4.288 <<< CONVERGED
>>> SOLUTION NOT CONVERGED AFTER 25 EQUILIBRIUM ITERATIONS
*** LOAD STEP 1 SUBSTEP 1 NOT COMPLETED. CUM ITER = 25
*** BEGIN BISECTION NUMBER 1 NEW TIME INCREMENT= 0.25000E-01
equations.
*** NOTE *** CP = 3864.141 TIME= 09:48:34
data.
*** WARNING *** CP = 3864.141 TIME= 09:48:34
212766 UX.
DISP CONVERGENCE VALUE = 6.298 CRITERION= 0.3213
HDSP CONVERGENCE VALUE = 564.4 CRITERION= 28.22
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -6.298
DISP CONVERGENCE VALUE = 6.298 CRITERION= 0.3279
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -6.298
5 FORCE-DISTRIBUTED CONSTRAINTS DO NOT SATISFY COMPATIBILITY CONDITION
FORCE CONVERGENCE VALUE = 48.51 CRITERION= 4.448
VOLUME CONVERGENCE VALUE = 0.9345E-03 CRITERION= 1.347 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.9306
DISP CONVERGENCE VALUE = 0.9306 CRITERION= 0.3346
HDSP CONVERGENCE VALUE = 288.2 CRITERION= 39.85
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.9306
FORCE CONVERGENCE VALUE = 459.8 CRITERION= 4.191
VOLUME CONVERGENCE VALUE = 0.3319E-02 CRITERION= 1.375 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4342E-01
DISP CONVERGENCE VALUE = 0.4021E-01 CRITERION= 0.3414 <<< CONVERGED
HDSP CONVERGENCE VALUE = 243.3 CRITERION= 51.06
LINE SEARCH PARAMETER = 0.9262 SCALED MAX DOF INC = 0.4021E-01
FORCE CONVERGENCE VALUE = 535.7 CRITERION= 7.906
VOLUME CONVERGENCE VALUE = 0.9928E-03 CRITERION= 1.403 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1251
DISP CONVERGENCE VALUE = 0.1251 CRITERION= 0.3484 <<< CONVERGED
HDSP CONVERGENCE VALUE = 180.7 CRITERION= 58.03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1251
FORCE CONVERGENCE VALUE = 856.4 CRITERION= 11.05
VOLUME CONVERGENCE VALUE = 0.1172E-02 CRITERION= 1.431 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2069
DISP CONVERGENCE VALUE = 0.2069 CRITERION= 0.3555 <<< CONVERGED
HDSP CONVERGENCE VALUE = 155.4 CRITERION= 58.03
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.2069
FORCE CONVERGENCE VALUE = 481.5 CRITERION= 4.466
VOLUME CONVERGENCE VALUE = 0.1504E-02 CRITERION= 1.460 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1391
DISP CONVERGENCE VALUE = 0.1391 CRITERION= 0.3627 <<< CONVERGED
HDSP CONVERGENCE VALUE = 110.8 CRITERION= 58.33
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1391
FORCE CONVERGENCE VALUE = 239.8 CRITERION= 4.565
VOLUME CONVERGENCE VALUE = 0.6167E-03 CRITERION= 1.490 <<< CONVERGED
EQUIL ITER 7 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1241
DISP CONVERGENCE VALUE = 0.1241 CRITERION= 0.3706 <<< CONVERGED
HDSP CONVERGENCE VALUE = 75.75 CRITERION= 60.50
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1241
FORCE CONVERGENCE VALUE = 146.7 CRITERION= 5.681
VOLUME CONVERGENCE VALUE = 0.3457E-03 CRITERION= 1.521 <<< CONVERGED
EQUIL ITER 8 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1499
DISP CONVERGENCE VALUE = 0.1499 CRITERION= 0.3795 <<< CONVERGED
HDSP CONVERGENCE VALUE = 70.01 CRITERION= 62.89
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1499
FORCE CONVERGENCE VALUE = 99.35 CRITERION= 5.464
VOLUME CONVERGENCE VALUE = 0.2470E-03 CRITERION= 1.552 <<< CONVERGED
EQUIL ITER 9 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1670
DISP CONVERGENCE VALUE = 0.1670 CRITERION= 0.3885 <<< CONVERGED
HDSP CONVERGENCE VALUE = 69.30 CRITERION= 65.30
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1670
FORCE CONVERGENCE VALUE = 99.16 CRITERION= 5.671
VOLUME CONVERGENCE VALUE = 0.2622E-03 CRITERION= 1.583 <<< CONVERGED
EQUIL ITER 10 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1707
DISP CONVERGENCE VALUE = 0.1707 CRITERION= 0.3978 <<< CONVERGED
HDSP CONVERGENCE VALUE = 67.60 CRITERION= 67.75 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1707
FORCE CONVERGENCE VALUE = 83.28 CRITERION= 12.18
VOLUME CONVERGENCE VALUE = 0.2559E-03 CRITERION= 3.231 <<< CONVERGED
EQUIL ITER 11 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1732
DISP CONVERGENCE VALUE = 0.1732 CRITERION= 0.4073 <<< CONVERGED
HDSP CONVERGENCE VALUE = 65.59 CRITERION= 70.18 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1732
FORCE CONVERGENCE VALUE = 78.72 CRITERION= 12.97
VOLUME CONVERGENCE VALUE = 0.2731E-03 CRITERION= 3.297 <<< CONVERGED
EQUIL ITER 12 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1727
DISP CONVERGENCE VALUE = 0.1727 CRITERION= 0.4170 <<< CONVERGED
HDSP CONVERGENCE VALUE = 65.19 CRITERION= 72.62 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1727
FORCE CONVERGENCE VALUE = 79.78 CRITERION= 13.49
VOLUME CONVERGENCE VALUE = 0.2829E-03 CRITERION= 3.365 <<< CONVERGED
EQUIL ITER 13 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1732
DISP CONVERGENCE VALUE = 0.1732 CRITERION= 0.4270 <<< CONVERGED
HDSP CONVERGENCE VALUE = 64.63 CRITERION= 75.03 <<< CONVERGED
FORCE CONVERGENCE VALUE = 74.09 CRITERION= 14.17
VOLUME CONVERGENCE VALUE = 0.2982E-03 CRITERION= 3.433 <<< CONVERGED
EQUIL ITER 14 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1723
DISP CONVERGENCE VALUE = 0.1723 CRITERION= 0.4373 <<< CONVERGED
HDSP CONVERGENCE VALUE = 64.90 CRITERION= 77.42 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1723
FORCE CONVERGENCE VALUE = 72.26 CRITERION= 14.82
VOLUME CONVERGENCE VALUE = 0.3197E-03 CRITERION= 3.503 <<< CONVERGED
EQUIL ITER 15 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1725
DISP CONVERGENCE VALUE = 0.1725 CRITERION= 0.4479 <<< CONVERGED
HDSP CONVERGENCE VALUE = 65.10 CRITERION= 79.82 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1725
FORCE CONVERGENCE VALUE = 70.66 CRITERION= 15.37
VOLUME CONVERGENCE VALUE = 0.3363E-03 CRITERION= 3.575 <<< CONVERGED
EQUIL ITER 16 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1754
DISP CONVERGENCE VALUE = 0.1754 CRITERION= 0.4588 <<< CONVERGED
HDSP CONVERGENCE VALUE = 64.35 CRITERION= 82.23 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1754
FORCE CONVERGENCE VALUE = 73.18 CRITERION= 15.99
VOLUME CONVERGENCE VALUE = 0.3536E-03 CRITERION= 3.648 <<< CONVERGED
EQUIL ITER 17 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1776
DISP CONVERGENCE VALUE = 0.1776 CRITERION= 0.4700 <<< CONVERGED
HDSP CONVERGENCE VALUE = 63.62 CRITERION= 84.64 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1776
FORCE CONVERGENCE VALUE = 75.44 CRITERION= 16.61
VOLUME CONVERGENCE VALUE = 0.3766E-03 CRITERION= 3.722 <<< CONVERGED
EQUIL ITER 18 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1795
DISP CONVERGENCE VALUE = 0.1760 CRITERION= 0.4814 <<< CONVERGED
HDSP CONVERGENCE VALUE = 61.73 CRITERION= 86.97 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9806 SCALED MAX DOF INC = 0.1760
FORCE CONVERGENCE VALUE = 69.90 CRITERION= 17.28
VOLUME CONVERGENCE VALUE = 0.3963E-03 CRITERION= 3.798 <<< CONVERGED
EQUIL ITER 19 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1820
DISP CONVERGENCE VALUE = 0.1820 CRITERION= 0.4931 <<< CONVERGED
HDSP CONVERGENCE VALUE = 62.02 CRITERION= 89.36 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1820
FORCE CONVERGENCE VALUE = 76.15 CRITERION= 17.84
VOLUME CONVERGENCE VALUE = 0.4239E-03 CRITERION= 3.876 <<< CONVERGED
EQUIL ITER 20 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1828
DISP CONVERGENCE VALUE = 0.1828 CRITERION= 0.5050 <<< CONVERGED
HDSP CONVERGENCE VALUE = 61.21 CRITERION= 91.71 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1828
FORCE CONVERGENCE VALUE = 76.75 CRITERION= 18.35
VOLUME CONVERGENCE VALUE = 0.4429E-03 CRITERION= 3.955 <<< CONVERGED
EQUIL ITER 21 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1830
DISP CONVERGENCE VALUE = 0.1830 CRITERION= 0.5172 <<< CONVERGED
HDSP CONVERGENCE VALUE = 59.68 CRITERION= 94.01 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1830
FORCE CONVERGENCE VALUE = 78.51 CRITERION= 18.92
VOLUME CONVERGENCE VALUE = 0.4727E-03 CRITERION= 4.035 <<< CONVERGED
EQUIL ITER 22 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1837
DISP CONVERGENCE VALUE = 0.1837 CRITERION= 0.5297 <<< CONVERGED
HDSP CONVERGENCE VALUE = 57.98 CRITERION= 96.23 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1837
FORCE CONVERGENCE VALUE = 83.17 CRITERION= 19.47
VOLUME CONVERGENCE VALUE = 0.4867E-03 CRITERION= 4.118 <<< CONVERGED
EQUIL ITER 23 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1814
DISP CONVERGENCE VALUE = 0.1814 CRITERION= 0.5424 <<< CONVERGED
HDSP CONVERGENCE VALUE = 57.62 CRITERION= 98.39 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1814
FORCE CONVERGENCE VALUE = 76.19 CRITERION= 20.03
VOLUME CONVERGENCE VALUE = 0.5039E-03 CRITERION= 4.202 <<< CONVERGED
EQUIL ITER 24 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1803
DISP CONVERGENCE VALUE = 0.1803 CRITERION= 0.5554 <<< CONVERGED
HDSP CONVERGENCE VALUE = 56.75 CRITERION= 100.5 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1803
FORCE CONVERGENCE VALUE = 76.15 CRITERION= 20.58
VOLUME CONVERGENCE VALUE = 0.5183E-03 CRITERION= 4.288 <<< CONVERGED
EQUIL ITER 25 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.1802
DISP CONVERGENCE VALUE = 0.1802 CRITERION= 0.5573 <<< CONVERGED
HDSP CONVERGENCE VALUE = 55.78 CRITERION= 102.5 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.1802
FORCE CONVERGENCE VALUE = 71.76 CRITERION= 20.68
VOLUME CONVERGENCE VALUE = 0.5321E-03 CRITERION= 4.288 <<< CONVERGED
*** LOAD STEP 1 SUBSTEP 1 NOT COMPLETED. CUM ITER = 50
*** BEGIN BISECTION NUMBER 2 NEW TIME INCREMENT= 0.12500E-01
equations.
*** NOTE *** CP = 7314.375 TIME= 10:03:46
data.
*** WARNING *** CP = 7314.375 TIME= 10:03:46
212766 UX.
DISP CONVERGENCE VALUE = 3.149 CRITERION= 0.1607
HDSP CONVERGENCE VALUE = 282.2 CRITERION= 14.11
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -3.149
DISP CONVERGENCE VALUE = 3.149 CRITERION= 0.1639
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -3.149
FORCE CONVERGENCE VALUE = 5.220 CRITERION= 2.169
VOLUME CONVERGENCE VALUE = 0.2330E-03 CRITERION= 1.347 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2179
DISP CONVERGENCE VALUE = 0.2179 CRITERION= 0.1673
HDSP CONVERGENCE VALUE = 117.4 CRITERION= 19.11
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.2179
FORCE CONVERGENCE VALUE = 3.659 CRITERION= 1.465
VOLUME CONVERGENCE VALUE = 0.2230E-03 CRITERION= 1.375 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.3791E-01
DISP CONVERGENCE VALUE = 0.2733E-01 CRITERION= 0.1707 <<< CONVERGED
HDSP CONVERGENCE VALUE = 72.49 CRITERION= 22.66
LINE SEARCH PARAMETER = 0.7211 SCALED MAX DOF INC = -0.2733E-01
FORCE CONVERGENCE VALUE = 2.371 CRITERION= 1.621
VOLUME CONVERGENCE VALUE = 0.7522E-04 CRITERION= 1.403 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4646E-01
DISP CONVERGENCE VALUE = 0.3081E-01 CRITERION= 0.1742 <<< CONVERGED
HDSP CONVERGENCE VALUE = 63.96 CRITERION= 25.78
LINE SEARCH PARAMETER = 0.6631 SCALED MAX DOF INC = -0.3081E-01
FORCE CONVERGENCE VALUE = 2.353 CRITERION= 1.790
VOLUME CONVERGENCE VALUE = 0.3989E-04 CRITERION= 1.431 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4897E-01
DISP CONVERGENCE VALUE = 0.3159E-01 CRITERION= 0.1777 <<< CONVERGED
HDSP CONVERGENCE VALUE = 60.38 CRITERION= 28.72
LINE SEARCH PARAMETER = 0.6451 SCALED MAX DOF INC = -0.3159E-01
FORCE CONVERGENCE VALUE = 2.506 CRITERION= 1.965
VOLUME CONVERGENCE VALUE = 0.2894E-04 CRITERION= 1.460 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4938E-01
DISP CONVERGENCE VALUE = 0.4938E-01 CRITERION= 0.1814 <<< CONVERGED
HDSP CONVERGENCE VALUE = 91.14 CRITERION= 33.16
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.4938E-01
FORCE CONVERGENCE VALUE = 25.52 CRITERION= 2.227
VOLUME CONVERGENCE VALUE = 0.7246E-04 CRITERION= 1.490 <<< CONVERGED
EQUIL ITER 7 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4807E-01
DISP CONVERGENCE VALUE = 0.2326E-01 CRITERION= 0.1851 <<< CONVERGED
HDSP CONVERGENCE VALUE = 42.48 CRITERION= 35.22
LINE SEARCH PARAMETER = 0.4839 SCALED MAX DOF INC = -0.2326E-01
FORCE CONVERGENCE VALUE = 16.20 CRITERION= 2.311
VOLUME CONVERGENCE VALUE = 0.6536E-04 CRITERION= 1.521 <<< CONVERGED
EQUIL ITER 8 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4715E-01
DISP CONVERGENCE VALUE = 0.1741E-01 CRITERION= 0.1888 <<< CONVERGED
HDSP CONVERGENCE VALUE = 31.41 CRITERION= 36.75 <<< CONVERGED
LINE SEARCH PARAMETER = 0.3693 SCALED MAX DOF INC = -0.1741E-01
FORCE CONVERGENCE VALUE = 13.99 CRITERION= 2.424
VOLUME CONVERGENCE VALUE = 0.5105E-04 CRITERION= 1.552 <<< CONVERGED
EQUIL ITER 9 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4648E-01
DISP CONVERGENCE VALUE = 0.6643E-02 CRITERION= 0.1927 <<< CONVERGED
HDSP CONVERGENCE VALUE = 11.86 CRITERION= 37.33 <<< CONVERGED
LINE SEARCH PARAMETER = 0.1429 SCALED MAX DOF INC = -0.6643E-02
FORCE CONVERGENCE VALUE = 13.62 CRITERION= 4.965
VOLUME CONVERGENCE VALUE = 0.4560E-04 CRITERION= 3.167 <<< CONVERGED
EQUIL ITER 10 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4629E-01
DISP CONVERGENCE VALUE = 0.3718E-02 CRITERION= 0.1966 <<< CONVERGED
HDSP CONVERGENCE VALUE = 6.572 CRITERION= 37.65 <<< CONVERGED
LINE SEARCH PARAMETER = 0.8033E-01 SCALED MAX DOF INC = -0.3718E-02
FORCE CONVERGENCE VALUE = 12.78 CRITERION= 5.086
VOLUME CONVERGENCE VALUE = 0.4247E-04 CRITERION= 3.231 <<< CONVERGED
EQUIL ITER 11 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4615E-01
DISP CONVERGENCE VALUE = 0.8671E-02 CRITERION= 0.2006 <<< CONVERGED
HDSP CONVERGENCE VALUE = 15.25 CRITERION= 38.39 <<< CONVERGED
LINE SEARCH PARAMETER = 0.1879 SCALED MAX DOF INC = -0.8671E-02
FORCE CONVERGENCE VALUE = 12.11 CRITERION= 5.254
VOLUME CONVERGENCE VALUE = 0.3661E-04 CRITERION= 3.297 <<< CONVERGED
EQUIL ITER 12 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4580E-01
DISP CONVERGENCE VALUE = 0.4514E-02 CRITERION= 0.2047 <<< CONVERGED
HDSP CONVERGENCE VALUE = 7.856 CRITERION= 38.77 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9856E-01 SCALED MAX DOF INC = -0.4514E-02
FORCE CONVERGENCE VALUE = 13.16 CRITERION= 5.404
VOLUME CONVERGENCE VALUE = 0.3315E-04 CRITERION= 3.365 <<< CONVERGED
EQUIL ITER 13 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.4570E-01
DISP CONVERGENCE VALUE = 0.4570E-01 CRITERION= 0.2089 <<< CONVERGED
HDSP CONVERGENCE VALUE = 78.26 CRITERION= 42.57
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.4570E-01
FORCE CONVERGENCE VALUE = 120.9 CRITERION= 1.852
VOLUME CONVERGENCE VALUE = 0.1549E-03 CRITERION= 1.717 <<< CONVERGED
EQUIL ITER 14 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.4434E-01
DISP CONVERGENCE VALUE = 0.4434E-01 CRITERION= 0.2132 <<< CONVERGED
HDSP CONVERGENCE VALUE = 65.90 CRITERION= 45.64
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.4434E-01
FORCE CONVERGENCE VALUE = 232.5 CRITERION= 4.567
VOLUME CONVERGENCE VALUE = 0.1445E-03 CRITERION= 1.752 <<< CONVERGED
EQUIL ITER 15 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6410E-01
DISP CONVERGENCE VALUE = 0.6410E-01 CRITERION= 0.2175 <<< CONVERGED
HDSP CONVERGENCE VALUE = 52.26 CRITERION= 47.13
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.6410E-01
FORCE CONVERGENCE VALUE = 180.9 CRITERION= 2.052
VOLUME CONVERGENCE VALUE = 0.2712E-03 CRITERION= 1.787 <<< CONVERGED
EQUIL ITER 16 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6454E-01
DISP CONVERGENCE VALUE = 0.6454E-01 CRITERION= 0.2220 <<< CONVERGED
HDSP CONVERGENCE VALUE = 41.01 CRITERION= 47.85 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.6454E-01
FORCE CONVERGENCE VALUE = 94.15 CRITERION= 6.335
VOLUME CONVERGENCE VALUE = 0.2235E-03 CRITERION= 3.648 <<< CONVERGED
EQUIL ITER 17 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.6469E-01
DISP CONVERGENCE VALUE = 0.6469E-01 CRITERION= 0.2265 <<< CONVERGED
HDSP CONVERGENCE VALUE = 34.28 CRITERION= 48.49 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.6469E-01
FORCE CONVERGENCE VALUE = 72.08 CRITERION= 8.470
VOLUME CONVERGENCE VALUE = 0.1098E-03 CRITERION= 3.722 <<< CONVERGED
EQUIL ITER 18 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5824E-01
DISP CONVERGENCE VALUE = 0.5824E-01 CRITERION= 0.2311 <<< CONVERGED
HDSP CONVERGENCE VALUE = 31.93 CRITERION= 49.29 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5824E-01
FORCE CONVERGENCE VALUE = 76.67 CRITERION= 8.979
VOLUME CONVERGENCE VALUE = 0.6550E-04 CRITERION= 3.798 <<< CONVERGED
EQUIL ITER 19 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5537E-01
DISP CONVERGENCE VALUE = 0.5537E-01 CRITERION= 0.2358 <<< CONVERGED
HDSP CONVERGENCE VALUE = 29.88 CRITERION= 50.06 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5537E-01
FORCE CONVERGENCE VALUE = 69.91 CRITERION= 9.385
VOLUME CONVERGENCE VALUE = 0.5575E-04 CRITERION= 3.876 <<< CONVERGED
EQUIL ITER 20 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5881E-01
DISP CONVERGENCE VALUE = 0.5881E-01 CRITERION= 0.2407 <<< CONVERGED
HDSP CONVERGENCE VALUE = 28.65 CRITERION= 50.79 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5881E-01
FORCE CONVERGENCE VALUE = 63.88 CRITERION= 9.892
VOLUME CONVERGENCE VALUE = 0.3849E-04 CRITERION= 3.955 <<< CONVERGED
EQUIL ITER 21 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5631E-01
DISP CONVERGENCE VALUE = 0.5631E-01 CRITERION= 0.2460 <<< CONVERGED
HDSP CONVERGENCE VALUE = 26.42 CRITERION= 51.54 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5631E-01
FORCE CONVERGENCE VALUE = 73.30 CRITERION= 10.17
VOLUME CONVERGENCE VALUE = 0.3638E-04 CRITERION= 4.035 <<< CONVERGED
EQUIL ITER 22 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5523E-01
DISP CONVERGENCE VALUE = 0.5481E-01 CRITERION= 0.2514 <<< CONVERGED
HDSP CONVERGENCE VALUE = 25.06 CRITERION= 52.27 <<< CONVERGED
LINE SEARCH PARAMETER = 0.9922 SCALED MAX DOF INC = 0.5481E-01
FORCE CONVERGENCE VALUE = 52.45 CRITERION= 10.64
VOLUME CONVERGENCE VALUE = 0.3791E-04 CRITERION= 4.118 <<< CONVERGED
EQUIL ITER 23 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5487E-01
DISP CONVERGENCE VALUE = 0.5487E-01 CRITERION= 0.2570 <<< CONVERGED
HDSP CONVERGENCE VALUE = 24.20 CRITERION= 52.99 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5487E-01
FORCE CONVERGENCE VALUE = 85.43 CRITERION= 10.88
VOLUME CONVERGENCE VALUE = 0.3865E-04 CRITERION= 4.202 <<< CONVERGED
EQUIL ITER 24 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5343E-01
DISP CONVERGENCE VALUE = 0.5343E-01 CRITERION= 0.2626 <<< CONVERGED
HDSP CONVERGENCE VALUE = 22.77 CRITERION= 53.70 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5343E-01
FORCE CONVERGENCE VALUE = 88.31 CRITERION= 11.32
VOLUME CONVERGENCE VALUE = 0.4279E-04 CRITERION= 4.288 <<< CONVERGED
EQUIL ITER 25 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.5220E-01
DISP CONVERGENCE VALUE = 0.5220E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 21.99 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = 0.5220E-01
FORCE CONVERGENCE VALUE = 66.34 CRITERION= 11.45
VOLUME CONVERGENCE VALUE = 0.3270E-04 CRITERION= 4.288 <<< CONVERGED
*** LOAD STEP 1 SUBSTEP 1 NOT COMPLETED. CUM ITER = 75
*** BEGIN BISECTION NUMBER 3 NEW TIME INCREMENT= 0.50000E-02
*** WARNING *** CP = 11605.609 TIME= 10:22:20
The default values that can be modified on the CNVTOL command have been
internally reset to CNVTOL tolerance TOLER = 5.0E-2 due to convergence
difficulties and the analysis is continued. Please verify the
analysis with this adjusted value of TOLER. You may need to specify
the NSUBST or CNVTOL commands for convergence and accuracy of the
solution. This automatic resetting of TOLER and VALUE can be turned
off if you include the CNVTOL command in the input.
equations.
FORCE CONVERGENCE VALUE = 0.000 CRITERION= 1147.
VOLUME CONVERGENCE VALUE = 0.000 CRITERION= 12.94
*** NOTE *** CP = 11671.469 TIME= 10:22:40
data.
*** WARNING *** CP = 11671.469 TIME= 10:22:40
212766 UX.
DISP CONVERGENCE VALUE = 1.260 CRITERION= 0.2631
HDSP CONVERGENCE VALUE = 112.9 CRITERION= 54.41
EQUIL ITER 1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -1.260
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -1.260
4 FORCE-DISTRIBUTED CONSTRAINTS DO NOT SATISFY COMPATIBILITY CONDITION
FORCE CONVERGENCE VALUE = 0.8350 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.3728E-04 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.5854E-01
DISP CONVERGENCE VALUE = 0.5854E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 41.23 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 1.000 SCALED MAX DOF INC = -0.5854E-01
FORCE CONVERGENCE VALUE = 0.4217 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2218E-04 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 3 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2010E-01
DISP CONVERGENCE VALUE = 0.1234E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 22.41 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6139 SCALED MAX DOF INC = -0.1234E-01
FORCE CONVERGENCE VALUE = 0.3260 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1047E-04 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 4 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.2007E-01
DISP CONVERGENCE VALUE = 0.1239E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 21.90 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6174 SCALED MAX DOF INC = -0.1239E-01
FORCE CONVERGENCE VALUE = 0.3240 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.5994E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 5 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1972E-01
DISP CONVERGENCE VALUE = 0.1235E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 21.59 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6261 SCALED MAX DOF INC = -0.1235E-01
FORCE CONVERGENCE VALUE = 0.3438 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.4266E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 6 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1924E-01
DISP CONVERGENCE VALUE = 0.1218E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 21.21 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6328 SCALED MAX DOF INC = -0.1218E-01
FORCE CONVERGENCE VALUE = 0.3673 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.3558E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 7 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1872E-01
DISP CONVERGENCE VALUE = 0.1194E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 20.77 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6378 SCALED MAX DOF INC = -0.1194E-01
FORCE CONVERGENCE VALUE = 0.3901 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.3212E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 8 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1819E-01
DISP CONVERGENCE VALUE = 0.1168E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 20.31 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6419 SCALED MAX DOF INC = -0.1168E-01
FORCE CONVERGENCE VALUE = 0.4111 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2995E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 9 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1766E-01
DISP CONVERGENCE VALUE = 0.1140E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 19.83 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6453 SCALED MAX DOF INC = -0.1140E-01
FORCE CONVERGENCE VALUE = 0.4300 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2826E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 10 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1715E-01
DISP CONVERGENCE VALUE = 0.1111E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 19.34 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6481 SCALED MAX DOF INC = -0.1111E-01
FORCE CONVERGENCE VALUE = 0.4467 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2676E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 11 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1664E-01
DISP CONVERGENCE VALUE = 0.1083E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 18.86 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6506 SCALED MAX DOF INC = -0.1083E-01
FORCE CONVERGENCE VALUE = 0.4613 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2537E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 12 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1615E-01
DISP CONVERGENCE VALUE = 0.1054E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 18.37 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6527 SCALED MAX DOF INC = -0.1054E-01
FORCE CONVERGENCE VALUE = 0.4740 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2404E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 13 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1567E-01
DISP CONVERGENCE VALUE = 0.1026E-01 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 17.88 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6546 SCALED MAX DOF INC = -0.1026E-01
FORCE CONVERGENCE VALUE = 0.4848 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2278E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 14 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1521E-01
DISP CONVERGENCE VALUE = 0.9980E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 17.41 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6562 SCALED MAX DOF INC = -0.9980E-02
FORCE CONVERGENCE VALUE = 0.4940 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2158E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 15 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1475E-01
DISP CONVERGENCE VALUE = 0.9704E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 16.93 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6577 SCALED MAX DOF INC = -0.9704E-02
FORCE CONVERGENCE VALUE = 0.5015 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.2043E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 16 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1431E-01
DISP CONVERGENCE VALUE = 0.9433E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 16.47 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6590 SCALED MAX DOF INC = -0.9433E-02
FORCE CONVERGENCE VALUE = 0.5076 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1934E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 17 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1389E-01
DISP CONVERGENCE VALUE = 0.9167E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 16.01 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6602 SCALED MAX DOF INC = -0.9167E-02
FORCE CONVERGENCE VALUE = 0.5122 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1831E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 18 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1347E-01
DISP CONVERGENCE VALUE = 0.8906E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 15.57 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6612 SCALED MAX DOF INC = -0.8906E-02
FORCE CONVERGENCE VALUE = 0.5157 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1733E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 19 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1307E-01
DISP CONVERGENCE VALUE = 0.8652E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 15.13 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6622 SCALED MAX DOF INC = -0.8652E-02
FORCE CONVERGENCE VALUE = 0.5179 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1639E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 20 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1267E-01
DISP CONVERGENCE VALUE = 0.8403E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 14.70 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6631 SCALED MAX DOF INC = -0.8403E-02
FORCE CONVERGENCE VALUE = 0.5191 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1551E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 21 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1229E-01
DISP CONVERGENCE VALUE = 0.8160E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 14.28 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6639 SCALED MAX DOF INC = -0.8160E-02
FORCE CONVERGENCE VALUE = 0.5192 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1467E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 22 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1192E-01
DISP CONVERGENCE VALUE = 0.7923E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 13.87 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6646 SCALED MAX DOF INC = -0.7923E-02
FORCE CONVERGENCE VALUE = 0.5185 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1388E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 23 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1156E-01
DISP CONVERGENCE VALUE = 0.7692E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 13.48 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6653 SCALED MAX DOF INC = -0.7692E-02
FORCE CONVERGENCE VALUE = 0.5169 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1313E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 24 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1121E-01
DISP CONVERGENCE VALUE = 0.7467E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 13.09 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6659 SCALED MAX DOF INC = -0.7467E-02
FORCE CONVERGENCE VALUE = 0.5146 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1243E-05 CRITERION= 12.94 <<< CONVERGED
EQUIL ITER 25 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.1088E-01
DISP CONVERGENCE VALUE = 0.7248E-02 CRITERION= 0.2631 <<< CONVERGED
HDSP CONVERGENCE VALUE = 12.71 CRITERION= 54.41 <<< CONVERGED
LINE SEARCH PARAMETER = 0.6664 SCALED MAX DOF INC = -0.7248E-02
FORCE CONVERGENCE VALUE = 0.5115 CRITERION= 1147. <<< CONVERGED
VOLUME CONVERGENCE VALUE = 0.1176E-05 CRITERION= 12.94 <<< CONVERGED
*** ERROR *** CP = 16083.547 TIME= 10:41:44
Solution not converged at time 5.E-03 (load step 1 substep 1).
Run terminated.
*** WARNING *** CP = 16083.547 TIME= 10:41:44
The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose.
R E S T A R T I N F O R M A T I O N
REASON FOR TERMINATION. . . . . . . . . .UNCONVERGED SOLUTION
RESTART BY RE-RUNNING THE ANALYSIS
ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.db
NUMBER OF WARNING MESSAGES ENCOUNTERED= 9
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
+--------------------- A N S Y S S T A T I S T I C S ------------------------+
Release: 2019 R3 Build: 19.5 Update: UP20190805 Platform: WINDOWS x64
Date Run: 01/05/2026 Time: 10:42 Process ID: 6240
Operating System: Windows 10 (Build: 26100)
Processor Model: Intel(R) Core(TM) i7-8700K CPU @ 3.70GHz
Compiler: Intel(R) FORTRAN Compiler Version 17.0.6 (Build: 20171215)
Intel(R) C/C++ Compiler Version 17.0.6 (Build: 20171215)
Intel(R) Math Kernel Library Version 2017.0.3 Product Build 20170413
Number of machines requested : 1
Total number of cores available : 12
Number of physical cores available : 6
Number of processes requested : 1
Number of threads per process requested : 4
Total number of cores requested : 4 (Shared Memory Parallel)
GPU Acceleration: Not Requested
Job Name: file
Input File: dummy.dat
Working Directory: D:\2M\_ProjectScratch\ScrA65F
Total CPU time for main thread : 4217.0 seconds
Total CPU time summed for all threads : 16156.5 seconds
Elapsed time spent pre-processing model (/PREP7) : 1.9 seconds
Elapsed time spent solution - preprocessing : 3.3 seconds
Elapsed time spent computing solution : 4227.8 seconds
Elapsed time spent solution - postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Equation solver used: Sparse (symmetric)
Equation solver computational rate : 83.2 Gflops
Equation solver effective I/O rate : 19.6 GB/sec
Maximum total memory used : 8241.0 MB
Maximum total memory allocated : 9944.0 MB
Total physical memory available : 32 GB
Total amount of I/O written to disk : 405.2 GB
Total amount of I/O read from disk : 972.2 GB
+------------------ E N D A N S Y S S T A T I S T I C S -------------------+
| ANSYS RUN COMPLETED|
| Ansys 2019 R3 Build 19.5 UP20190805 WINDOWS x64 |
| Database Requested(-db) 1024 MB Scratch Memory Requested 1024 MB |
| Maximum Database Used 599 MB Maximum Scratch Memory Used 7642 MB |
| CP Time (sec) = 16156.531 Time = 10:42:07 |
| Elapsed Time (sec) = 4239.000 Date = 01/05/2026 |
January 5, 2026 at 2:07 pm
peteroznewman
SubscriberPlease open a New Discussion with a relevant title since your problem has nothing to do with this discussion. In that new Discussion, include some images of the model and mesh.
