3D Design
3D Design
Internal solution magnitude limit was exceeded. Need help with error?
    • abdab
      If you drop a Modal Analysis on this Static Structural model and request 10 modes (not the default 6), you may see a body floating around and can take corrective action.
      Did you insert a Contact Tool into the Connections folder and evaluate Initial Contact Status? All contacts must show Closed. None can be Near Open or Far Open. Increasing the Pinball Radius on those may resolve the problem.
  • The topic ‘Internal solution magnitude limit was exceeded. Need help with error?’ is closed to new replies.
