LS Dyna
LS Dyna
Internal energy output of a set of shell elements
    • alikuryan
      Hi all,
      I am running a windshield impactor simulation in LS-DYNA, and I would like to obtain the internal energy output for a specific set of shell elements.
      I tried using ELOUT and DATABASE_HISTORY_SHELL, but so far I have not been able to find the internal energy output for the shell element set.
      Is there a way to directly output the internal energy of a selected set of shell elements in LS-DYNA?
      If this output is not available directly, what would be the recommended way to extract or calculate this data? For example, are there any post-processing scripts, LS-PrePost options, or other methods that could be used?
      Thank you.
    • Dennis Chen
      Hello, unless I am missing something, internal energy should be part of the database_matsum output.   Have you tried that and included in your input file?  If you have, try looking at the "matsum" output.
    • alikuryan
      Dear Mr. Chen,
      Thank you for your reply. Yes, I have also tried MATSUM, but it only provides the energy output for the entire part. What I need is the energy output for a specific set of shell elements, not for the whole part.
      Do you know if there is a way to obtain this energy output for a selected shell element set?
      Best regards,
      Ali
