January 5, 2025 at 2:39 am103200155Subscriber
Dear all,
I am currently learning to simulate a 3D IC engine through ANSYS Tutorial, and I'm having a hard time finding these files :
demo_eng.x_t, lift.prof, tut_comb_sect.x_t, injection-profile, Diesel_1comp_35sp_chem.inp, Diesel_1comp_35sp_therm.dat, tut_gdi_comb.x_t, comb_lift.prof, footprint.txt, massflowrate.csv, velocity-0.7cd.csv
In fact, all files related to the tutorial "ANSYS Internal Combustion Engines Tutorial Guide" really.
this is file tutorial : 'https://drive.google.com/file/d/107o60WdM6dQfhrSuvk-bVuegC45NSoRh/view?usp=drive_link'
Can anyone please help me out with this and share them with me? I would be very grateful.
this is my email : hungd317@gmail.com
Thank you all!
Kind regards,
hung.
January 6, 2025 at 9:42 amRobForum Moderator
Which tutorial? And where are you looking at it?
January 7, 2025 at 11:26 pm103200155Subscriber
oh sorry! i pasted the wrong file.
January 7, 2025 at 11:27 pm103200155Subscriber
Here sir :
" https://drive.google.com/file/d/107o60WdM6dQfhrSuvk-bVuegC45NSoRh/view?usp=drivesdk "
Looking forward to receiving your feedback
Kind regards
hung
January 8, 2025 at 9:55 amRobForum Moderator
I'm not permitted to open links, is it in the current documentation?
January 8, 2025 at 10:19 am103200155Subscriber
sorry to bother you, i want to find files similar to 6 videos in this link: https://innovationspace.ansys.com/knowledge/forums/topic/ansys-internal-combustion-engine-ice-engine-sector-combustion-part-1-getting-started/
January 9, 2025 at 11:14 amRobForum Moderator
The video is here, https://www.youtube.com/watch?v=UBjIUr7Es6I and you should be able to find the subsequent sections in the right hand column list. It's an older video, and the files aren't available; check the documentation to see what's there too as there are tutorials.
January 11, 2025 at 10:53 am103200155Subscriber
Thank you sir
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Overlapping contact face
- Thermoelectric Cooler Model
- Issue Seeing Explore
- Warning Plugin Error Geometry in Design Modeler
- SpaceClaim stops sharing topology
1411
599
591
555
366
