Internal and External Flow Setup in ANSYS Fluent/SpaceClaim
    • Ali
      I am simulating an aircraft with the engine running, which involves internal and external (engine) flows together. The aircraft is placed in a far-field domain with prescribed boundary conditions, while the engine inlet will have a different boundary condition applied. Both the external domain and the engine are in the same fluid medium (air).
      My main questions are:
      1. How should I model the computational domains? If I create a separate fluid volume inside the engine, the inlet and outlet become interfaces, which turn into internal boundaries in Fluent. How do I manage this appropriately for internal-external flow coupling?
      2. How should I apply the boundary conditions correctly? I need to ensure the boundary conditions for the far-field and engine components are handled properly.
      3. How do I prepare the geometry for this setup in SpaceClaim? Any suggestions on how to set up the computational domain in SpaceClaim? I want mesh and simulate in Fluent.
      I'm seeking guidance on the best practices for geometry preparation, domain setup, and boundary condition application in this type of simulation.
      Ali
      To clarify you want to model the external aircraft geometry and the whole engine? How much detail do you want to model for both parts?
      Have a look in Learning on here and Fluent's tutorials for more general information.
    • Ali
      Yes, I want to model the geometry of external aircraft and the engine as a whole. Engine inlet with mass flow boundary condition, nothing else will be modeled at this stage. Later, I want to model the whole engine except combustion.
