May 8, 2023 at 7:00 pm
Mohendro Ghosh
SubscriberDear Good Folks,
Greetings!
I need an urgent assistance in "Integrating Ansys Maxwell design into OptiSlang for Optimization". If some is experienced on this or has any effective tutorials (pdf or video) or want to help me directly through oline (zoom/skype) discussion, will be greatly appciated.Â
You can contact me @ [mkg57@pitt.edu].Â
Thanks in advance.Â
Dr. Mohendro Kumar Ghosh
May 9, 2023 at 10:06 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following link helps: Magnetic Gear Optimization with Ansys Maxwell and Ansys OptiSLang - PADT (padtinc.com)
Ashish Khemka
May 9, 2023 at 4:42 pm
Mohendro Ghosh
SubscriberHi Ashis, Thanks. This will also helpful for me. However, I am willing to design EV Motor by Ansys Maxwell and then export to OptiSlang. In this case, an e-motor solver will be needed, may be a small coding is also neede to create the solver. Which I am really looking for. If you know anything related to this, please let me know. Thanks in advance.Â
Mohendro.Â
June 12, 2023 at 1:51 pm
Oleg
Ansys EmployeeDear Mohendro,
Thank you for posting your request. Which steps are you missing in the video kindly mentioned by Ashish? Do you have your Maxwell project ready and solved before starting with optiSLang?
Kindest regards, Oleg
June 12, 2023 at 9:45 pm
Mohendro Ghosh
SubscriberHi Oleg,
Thanks for your reply. Yes My Maxwell project is ready.Â
In that video, everything is fine, but at ther final stage when I need to set objectives for optimization (min. weight and max. efficiency for example),
something is going wrong there. Also, there is no parametric variation in outputs.Â
Can you please help me in this regard? We can talk over zoom or skype? Alos, can you send me your email id for direct contact.Â
my email: mkg57@pitt.eduÂ
Thanks
Mohendro
June 12, 2023 at 4:31 pm
Mohendro Ghosh
SubscriberHi Oleg,
Thanks
Mohendro.Â
June 13, 2023 at 11:54 am
Oleg
My idea is that you do not reduce the data type of the AEDT reports to just scalar values. Please, review the Help Tutorial "optiSLang in optimetrics"; you don't need it whole, jump to the the Chapter "Defining responses". Here is the link: optiSLang in Optimetrics (ansys.com)
For a detailed discussion I suggest that you contact Technical Support and submit a Request there.
June 13, 2023 at 7:40 pm
Mohendro Ghosh
SubscriberHi Oleg,
Thanks for your reply. I can not access to this tutorial. I dont understand the reason.Â
Can you send me the same pdf to me @ (mkg57@pitt.edu)?
Thanks again.Â
Regards
Mohendro.Â
June 14, 2023 at 6:48 am
Oleg
Unfortunately, no, I can't send you the pdf, that doesn't work this way.
What happends when you access the tutorial on web?
And what about submitting a Request to the Support Team?
Kindest regards -- Oleg
- The topic ‘Integrating Ansys Maxwell design into OptiSlang for Optimization’ is closed to new replies.
6625
1311
