LS Dyna
LS Dyna
Insufficient memory available in contact.
    • pl96andy
      Hi
      I have received error in autodyn simulation "Insufficient memory available in contact.". What could possiebly be a cause of this error?
    • shervinjoses
      Go to Ansys Workbench - tools - options - Mechanical APDL - Database Memory, Workspace Memory increase memory allocation if possible
      Try opening Ansys in Admin mode- cause even though you enough memory allocated if you arenÔÇÖt in admin sometimes the problem seems to persist.
      Hopefully it works you
      cheers!!
    • pl96andy
      Thank you for your comment
      I've raised both database memory and workbench memory up to 4000 MB and error still occurs.
      I wonder if it might be connected with use of custom material definition.
      Because simulation runs smoothly with material from library.
      cheers
  • The topic ‘Insufficient memory available in contact.’ is closed to new replies.
