April 8, 2024 at 2:32 pm
acdlicen
SubscriberWhere can I find the command line installation sequence for HFSS on Linux64 (specifically Rocky Linux 8.7)?
April 11, 2024 at 9:06 am
Aymen Mzoughi
Ansys EmployeeThis video on Ansys Innovation Space explains the steps:
/knowledge/forums/topic/installing-the-ansys-electromagnetics-suite-on-linux/
For more detailed information you can check the "Ansys Electromagnetics Suite 2024 R1 Linux Installation Guide" available in the Ansys help documentation.
Here the steps:
1. Open the command prompt.
2. Use the cd command to navigate to the installation directory containing setup.exe
(Linux/AnsysEM/Disk1/InstData).
3. Run setup.exe using the -i silent option and append any installer properties for which you
want to deviate from the default value. Each property is prefixed with -D (with no space
between the D and the property name). Several examples follow:
Command Line Examples
l Example 1: Override the default installation directory and specify a single license server:
setup.exe -i silent -DUSER_INSTALL_DIR=-DSPECIFY_
LIC_CFG=1 -DLICENSE_SERVER1=
l Example 2: Force keeping the existing license configuration – if none currently exists, this
option will create a new configuration (specifying the local machine as the license server):
setup.exe -i silent -DKEEP_LIC_CFG=1
l Example 3: Configure a common library directory:
setup.exe -i silent -DLIBRARY_COMMON_INSTALL=1 -DLIBRARY_COMMON_
DIR=
l Example 4: Configure a custom temporary file directory and do not add read/write access
to this folder for all users:
setup.exe -i silent -DTMP_DIR=-DTMP_RW=0
l Example 5: Configure redundant license servers:
setup.exe -i silent -DSPECIFY_LIC_CFG=1 -DLICENSE_
SERVER1=-DREDUNDANT_SERVERS=1 -DLICENSE_
SERVER2=-DLICENSE_SERVER3=
- The topic ‘Installation sequence for ANSYS HFSS’ is closed to new replies.
