November 23, 2023 at 6:00 am
Avrok Ghosh
SubscriberI had a licensing issue a couple of days ago which made mechanical and spaceclaim to not open. I did a complete uninstall of ANSYS workbench 2023 and the license manager application. I reinstalled the license manager and added my license file which was successful. However I downloaded the structures package again and ran the setup file. The installation was successful and i had selected all the products to be installed on my computer. However when i run workbench now, not all component systems are showing. I need static structural as a system which is not available to me. I have attached the picture. The options are there in toolbox customisation, but am not able to insert them into the workspace.
November 24, 2023 at 12:44 pm
Rajeshwari Jadhav
Forum Moderator-
November 24, 2023 at 4:24 pm
November 24, 2023 at 3:29 pm
Ashish Khemka
Forum ModeratorHi Rajeshwari,
It looks it looks Avrok has created another post. Please see if the information here is useful or not: Component systems not showing in workbench 2023 (ansys.com)
Ashish Khemka
November 24, 2023 at 3:54 pm
Rajeshwari Jadhav
Forum ModeratorHi Avrok,
If License Manager is installed locally, then please mention localhost in Ansys Licensing Setting utility, click test and save it.
November 24, 2023 at 4:26 pm
November 24, 2023 at 5:22 pm
Rajeshwari Jadhav
Don't save it, still an error. Is the license manager and application on the same machine?
November 24, 2023 at 5:23 pm
Avrok Ghosh
SubscriberYes they're both on my laptop
Rajeshwari Jadhav
Forum ModeratorAre you able to ping or telnet your server, in the command prompt try using cmd “ping servername” and “telnet servername 1055”?
To ON telnet service go to start and search “Turn Windows feature on or off” check box “Telnet Client” and click ok.
Go to the start menu, open the command prompt, and run the below-mentioned commands:
- ping servername
type this command and send the screenshot of the output.
- telnet servername portnumber
A blank screen will confirm that you are connected, if you get any other output, please provide a screenshot of the same.
November 24, 2023 at 5:28 pm
November 24, 2023 at 5:34 pm
Rajeshwari Jadhav
Go to path C:\Program Files\ANSYS Inc\Shared Files\licensing\license_files (by deafult) open ansyslmd.ini file and instead of servername mention localhost. Restart the license manager once you do it. Launch the Ansys Licensing Settings Utility and mention localhost over there and save it. (run as admin)
November 24, 2023 at 6:03 pm
November 24, 2023 at 6:05 pm
Rajeshwari Jadhav
Forum ModeratorTry IP address instead of localhost
November 24, 2023 at 6:13 pm
November 24, 2023 at 6:15 pm
Rajeshwari Jadhav
Forum Moderatormention 127.0.0.1 instead
November 24, 2023 at 6:23 pm
- The topic ‘Component systems not showing in structures package’ is closed to new replies.
5649
1885
1404
1303
