August 7, 2023 at 5:53 pm
Savino Giovanni Muscio
Subscriber -
August 8, 2023 at 12:27 pm
Rajeshwari Jadhav
Forum ModeratorHi Savino,
This can be due to corrupt files, can you please download and have a fresh installation for Electronics?
August 9, 2023 at 1:49 pm
SubscriberNo no, this is not true. In the folder dowloaded is missing the file data.5
I tried to dowload two time and each time this file missing.
Any help?
August 9, 2023 at 2:09 pm
Rajeshwari Jadhav
You installed an ISO image right?Â
Can you please extract the file and then point the setup to that extracted file?
Please see if these links helps 4.1. Downloading the Installation Files (ansys.com) Â 3.1. Downloading the Installation Files (ansys.com)
Please confirm if you are following these steps:
• Windows - Extract the contents of the ISO file to a temporary directory, using an archiving utility such
as Winrar, Winzip, or 7zip. Run setup.exe from the top level folder.
• Linux - Mount the image, using "mount -o loop -t iso9660 filename.iso /mnt/iso" command. Run
"./INSTALL" from the top level folder -
August 9, 2023 at 2:22 pm
SubscriberHi, I will try. But now by following the link above i need to know some info:
Account Number(Customer Number). Where i can found it?
When i dowloade the software for the first time i never had need
August 9, 2023 at 2:24 pm
SubscriberSince i dont know it i will dowload the software by the link as i make the firs time:
Ansys Electronics Desktop Student Version | Free Software Download
August 9, 2023 at 2:29 pm
Rajeshwari Jadhav
Please goahead and download the software through the link you provided and instead of those links I sent you can find same information once you download the software (\StudentVersion\util)
August 9, 2023 at 2:55 pm
August 9, 2023 at 6:24 pm
Rajeshwari Jadhav
You need right-clicked on setup.exe and run it as admin. Did you do it?
August 9, 2023 at 6:37 pm
Subscriberfor sure, this is not the first time i install a software
August 9, 2023 at 6:39 pm
Subscribercan some one try to dowload the software and check if in the folder there is this kind of file called:
data.5.cab
this is the problem
August 9, 2023 at 6:43 pm
August 9, 2023 at 6:40 pm
Rajeshwari Jadhav
Forum ModeratorCan you go to event viewer and check if any Error is shown?
Go to START > Event Viewer > Expand the Windows Logs and choose Application.
August 9, 2023 at 8:56 pm
August 9, 2023 at 9:38 pm
August 10, 2023 at 8:10 am
Rajeshwari Jadhav
Can also try to rename the Ansoft folder, goto Documents-->Ansoft rename it to Ansoft.old and try again to reinstall. Also in event viewer check application and security logs both to see if any error gets logged into it.
August 11, 2023 at 1:19 am
SubscriberHi, same problem. I will check on the other laptop asap
September 7, 2023 at 6:12 pm
Leonardo Córdova
SubscriberÂ
hi, I have exactly the same problem, data5.cab file is not in the AnsysEMSV folder. Did you solve it?
Nothing above worked for me neither
September 8, 2023 at 11:38 am
SubscriberHi, i didnt fix it. I will try to install the software on one more laptop.
- The topic ‘Installation of Ansys for student’ is closed to new replies.
5054
1764
1387
1248
