3D Design
3D Design
Installation and Activation
    • Trevor Frost
      I tried to download Spaceclaim that we had renewed a while ago. I have just gotten around to it and I cannot get it to work. When I try to login to the software using my forum login, I get the pop-ups shown in the attached Activation Errors file. When I try to activate the license using the command window as suggested in the text file that contains the order, customer, and activation IDs, I get the error shown in the attached Activation Errors-Command Window file. What is wrong?
    • subashni.satish
      Hello Trevor Frost
      Discovery Named User products require an active internet connection to allow License activation.
      The error in the image shared says that you may have a Proxy setup which maybe blocking the license activation over internet.
      Please refer to the below page for proxy setup changes you need to make to allow Subscription activation.
      Discovery - Patch for addressing proxy server issues - Knowledge Base - Ansys Discovery Forum
  • The topic ‘Installation and Activation’ is closed to new replies.
