January 3, 2025 at 12:24 am
Jin_heyung
SubscriberInstall setup.exe by running it with right-click administrator privileges, but the error continues to occur.
Ansys 설치: 월 12 30 18:07:45 2024
개정: 2024 R2###### Error #######
Error executing configuration script 'AnsConfigDiscoUnified.tcl'
'C:\Users\파인캐~1\AppData\Local\Temp\ans_install_tmp40944\tcl\bin\winx64\tclsh.exe' terminated after 1 attempts with the following error(s):
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigDiscoUnified.tcl": no such file or directory
Error executing configuration script 'AnsConfigCommonDiscovery.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigCommonDiscovery.tcl": no such file or directory
Error executing configuration script 'AnsConfigADR.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigADR.tcl": no such file or directory
Error executing configuration script 'AnsConfigCommon.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigCommon.tcl": no such file or directory
Error executing configuration script 'AnsConfigHelp.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigHelp.tcl": no such file or directory
Error executing configuration script 'AnsConfigWB.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigWB.tcl": no such file or directory
Error executing configuration script 'AnsConfigRSM.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigRSM.tcl": no such file or directory
Error executing configuration script 'AnsConfigSpaceClaimUnified.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigSpaceClaimUnified.tcl": no such file or directory
Error executing configuration script 'AnsConfigCFX.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigCFX.tcl": no such file or directory
Error executing configuration script 'AnsConfigCHEMKIN.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigCHEMKIN.tcl": no such file or directory
Error executing configuration script 'AnsConfigEnSight.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigEnSight.tcl": no such file or directory
Error executing configuration script 'AnsConfigFENSAP.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigFENSAP.tcl": no such file or directory
Error executing configuration script 'AnsConfigCFDPost.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigCFDPost.tcl": no such file or directory
Error executing configuration script 'AnsConfigFLUENT.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigFLUENT.tcl": no such file or directory
Error executing configuration script 'AnsConfigPolyflow.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigPolyflow.tcl": no such file or directory
Error executing configuration script 'AnsConfigFORTE.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigFORTE.tcl": no such file or directory
Error executing configuration script 'AnsConfigRDWorkbench.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigRDWorkbench.tcl": no such file or directory
Error executing configuration script 'AnsConfigTG.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigTG.tcl": no such file or directory
Error executing configuration script 'AnsConfigSpeos.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigSpeos.tcl": no such file or directory
Error executing configuration script 'AnsConfigSpeosLabs.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigSpeosLabs.tcl": no such file or directory
Error executing configuration script 'AnsConfigAQWA.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigAQWA.tcl": no such file or directory
Error executing configuration script 'AnsConfigACP.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigACP.tcl": no such file or directory
Error executing configuration script 'AnsConfigANSYS.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigANSYS.tcl": no such file or directory
Error executing configuration script 'AnsConfigMotion.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigMotion.tcl": no such file or directory
Error executing configuration script 'AnsConfigClientLicensing.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigClientLicensing.tcl": no such file or directory
Error executing configuration script 'AnsConfigAVIEW.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigAVIEW.tcl": no such file or directory
Error executing configuration script 'AnsConfigOptiSLang.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigOptiSLang.tcl": no such file or directory
Error executing configuration script 'AnsConfigCAD.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigCAD.tcl": no such file or directory
Error executing configuration script 'AnsConfigSpeosCads.tcl'
Unknown error
Exit Code: 1
couldn't read file "C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp40944\config\AnsConfigSpeosCads.tcl": no such file or directory
January 3, 2025 at 12:26 am
Jin_heyung
Subscriber>>>--------------------------------------->
설치 시작: 금 1 03 09:19:25 2025
개정: 2024 R2플랫폼 세부 사항:
Windows
설치 프로그램의 사용자 이름: DESKTOP-CLSSTA1\ ij Ʈ
사용자에게 관리자 권한이 있습니다.
C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp17732\instcore.exe -usetempdir C:\Users\ ij~1\AppData\Local\Temp\ans_install_tmp17732 -launchdir C:\Users\파인캐스트\Desktop\ANSYSACADEMICSTUDENT_2024R2.1WINX64 -admin
초기 마운트 디렉토리:
설치 디렉토리:
C:\Program Files\ANSYS Inc\ANSYS StudentWindows x64
Design
Discovery
Ansys Dynamic Reporting
CFX (includes CFD-Post)
Chemkin
EnSight
FENSAP-ICE
Fluent (includes CFD-Post)
Forte (includes EnSight)
Model Fuel Library (Encrypted)
Polyflow (includes CFD-Post)
Reaction Workbench
TurboGrid
Geometry Interfaces
Discovery Geometry Interface
SpaceClaim Geometry Interface
Optical
Speos
Structures
Aqwa
Autodyn
Material Calibration App
Customization Files for User Programmable Features
Mechanical Products
Motion나중에 다시 구성해야 하거나 네트워크 공유에 설치된 제품에 대해 클라이언트 머신을 구성해야 하는 경우 설치 시 미디어에서 필수 설정 파일이 복사됩니다.
여기에는 시간이 소요될 수 있습니다.
미디어에서 필수 구성 요소를 성공적으로 복사했습니다.You don't need to install any prerequisites.
설치 미디어 내용물을 읽고 있습니다. 잠시 기다리십시오.
추출: C:\Users\파인캐스트\Desktop\ANSYSACADEMICSTUDENT_2024R2.1WINX64\instcore\tcl\COMMON.TGZ ...
추출: C:\Users\파인캐스트\Desktop\ANSYSACADEMICSTUDENT_2024R2.1WINX64\instcore\tcl\WINX64.TGZ ...
추출: C:\Users\파인캐스트\Desktop\ANSYSACADEMICSTUDENT_2024R2.1WINX64\cpythnew\WINX64.7z ...
RSS가 비활성화됨
파일 연결을 성공적으로 생성했습니다.경고/오류 발생으로 설치가 완료되었습니다. 다음에서 .err 또는 .log 파일을 검토하십시오.
C:\Program Files\ANSYS Inc\ANSYS Student설치 완료: 금 1 03 09:20:48 2025
<---------------------------------------<<<istall log
March 11, 2025 at 7:26 am
5669
1890
1419
1304
