Photonics
Photonics
Insert a curved rectangular beam (structure)
    • Rosmin_Elsa_Mohan
      Would like to check on how to include a thin curved rectangular beam of length about 20 um, as a structure in a simulation.
      Any standard scripts available for this, or any other approaches would be appreciated.
      Thanks,
      Rosmin
    • Amrita Pati
      Hi Rosmin,
      Is the beam supposed to have a constant radius of curvature? Is it supposed to look like a curved waveguide? Could you please share a screenshot of the structure? Thank you!
      Amrita
    • Amrita Pati
      If you can define the curvature directly by it's coordinates on a plane, or have an equation that can be used to generate the co-ordinates, then the simplest apporach would be to use a polygon object.
  • The topic ‘Insert a curved rectangular beam (structure)’ is closed to new replies.
