March 4, 2026 at 9:04 pm
mshreepal
SubscriberI am trying to replicate half filled pipe. I have flow rate of 40 l/s.Â
SImualtion type - Transient , VOF( Open channel) , Primary- AIr, Secondary - Water. For trial i am considering Laminar flow.
I defined free surface and bottom in Inlet BC.Â
Problem I am facing is my inlet is behaving like a waterfall. How to fix this ?Â
March 5, 2026 at 9:38 am
Forum ModeratorWhat's holding the water in at the other end?
March 5, 2026 at 2:02 pm
mshreepal
SubscriberThere is a pressure outlet on other side. It is a straight pipe.Â
March 5, 2026 at 2:07 pm
Forum ModeratorThere's an open channel outlet too, if you set a uniform pressure there's nothing to hold the water up so it's just flowing out with next to no depth. If the inlet speed isn't sufficient to fill the domain you get what you're seeing.Â
