April 24, 2020 at 3:46 pm
Clemence
SubscriberHi,Â
Here is the geometry that I want to mesh,Â
I want the air at 30 m/s to come in through the inlet side and come out through the outlet hole to influence the ball inside the torus.Â
To define the inlet and outlet, is it absolutely necessary to define a face or can they be edges? If I have a face at the inlet, will the air pass through or do I have to make an extrusion?Â
Thank youÂ
May 4, 2020 at 9:36 pm
RK
Ansys EmployeeHello,Â
You need to define a face at the inlet and outlet region.Â
May 6, 2020 at 2:56 am
Keyur Kanade
Ansys Employeeplease use named selection for faces.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
- The topic ‘Inlet and Outlet definition’ is closed to new replies.
1313
