July 30, 2025 at 3:36 pm
Jérôme RENAULT
SubscriberHello,
Further to my question regarding access to the AWG group pages, I'm getting the input files presenting a possible workflow for obtaining the initial stress state of a rotating engine part (described in § 5.1.1 and § 5.1.2 of the document LS‐DYNA® Aerospace Working Group "Modeling Guidelines Document" version 24.1).
I'm doing the same thing with my model, but I'm unable to obtain a steady state for my rotating part at the end of the second step. The main difference is that my model includes *ELEMENT_SHELL_OFFSET elements. So, I simply modified my input file by replacing the *ELEMENT_SHELL_OFFSET elements with *ELEMENT_SHELL elements, and the behavior seems much better, except for the triangular elements, which still don't reach the steady state.
Two questions at this point:
- Is it possible to use a prestress analysis following the workflow presented in the AWG document with offset shell elements and enabling additional options ? I need to use shell offset element as I will work with composite parts modelled with ACP.
- How do I handle the problem with triangular elements? (My part is a cone, which will be difficult to mesh with only quad elements, but not impossible, I admit.)
Best regards,
Jérôme
August 4, 2025 at 9:07 am
Jérôme RENAULT
SubscriberTo add some information to the topic ...
I try the second procedure which involves the dynamic relaxation. I get the same issue with offseted elements. Nevertheless, once applied on non offseted elements, the results is acceptable with the triangle shaped elements (no stress concentration and/or discontinuities around) compared with the first procedure.
By the way, the two questions of the first messages are still open.
Best regards,
Jérôme
August 5, 2025 at 5:36 am
igandiko
Ansys EmployeeHello, is it possible to share your files, perhaps through a support case? Have you tried running the latest version of the solver? Please check if adding drilling stiffness stabilization using DRCPSID in *control_shell helps (https://lsdyna.ansys.com/wp-content/uploads/2025/02/drilling-rotation-constraint-for-shell-elements-in-implicit-and-explicit-analyses.pdf).
Note that NLOC affects the stiffness of built-up section (overlayed elements). “[NLOC] Affects stiffness of a “built up” section. For example, two shells overlayed using the same nodal connectivity and NLOC=0 will have stiffness equal to the straight sum of the 2 shell stiffnesses. If they’re offset using NLOC=1 and NLOC=-1 respectively, the bending stiffness is increased in accordance with a net section thickness of thick1 + thick2.”
If dynamic relaxation with non-offset triangular elements provide reasonable results, please check the difference in results at t=0 with DR phase vs. implicit pre-stress analysis. Since the pre-stress analysis is implicit, I would follow the implicit guildelines and also turn on implicit accuracy flag. Note that you can also run implicit dynamic relaxation in the 2nd procedure for comparison.
August 5, 2025 at 1:42 pm
Jérôme RENAULT
SubscriberHello Igandiko,
I've tried your various suggestions (except a test with the last version, as I can only run 202R2 on my server) ... without success.
It's possible to share my files; please let me know how to proceed (maybe with customer support space page ?)
Best regards,
Jérôme
August 6, 2025 at 5:25 am
igandiko
Ansys EmployeeIf you're able to create a support case on Ansys customer support space, that would be ideal. Please let me know if you can.
If you cannot create a support case, then please email the files to support@ansys.com (along with this forum link) and request them to forward the query to LS-DYNA team. Thanks!
August 6, 2025 at 8:44 am
Jérôme RENAULT
No problem, I open the case 00437219
Best regards,
Jérôme
August 6, 2025 at 3:00 pm
Jérôme RENAULT
SubscriberAt the same time, I'm trying to find a solution on my own. Regarding point 2 and the triangular elements, activating the OSU option in *CONTROL_ACCURACY is a good solution. The triangular elements no longer evolve during the rotation phase until an external load is applied, of course.
Best regards,
Jérôme
5649
1885
1403
1303
