May 16, 2024 at 9:36 am
Haseeb Ahmad
SubscriberHello,
i am working on develop some relationships between inputs and outputs using FEM of bridge model like effect of change in elastic modulus on natural frequencies . My inputs are 10 and number of samples of each input lets say 100 but problem is, i have put these inputs everytime manually. is there any function in ANSYS that ANSYS automatically take these inputs values from text or CSV file by writting code or something else?
Thank you
May 17, 2024 at 1:32 pm
Chandra Sekaran
Ansys EmployeeYou can use parameter set in Workbench. In Mechanical you specify input / output parameters. Then in WB Project page you open the parameter set and add design points. Please take a look at below in the documentation.
Setting up parameters in Mechanical: Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_sim/ds_Parameters_Specifying.html
working with parameters: Â https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb2_help/wb2h_parameters.html
- The topic ‘Information about to put some inputs in ANSYS workbench.’ is closed to new replies.
