LS Dyna
LS Dyna
Inexistent dynain output with *INTERFACE_SPRINGBACK_SEAMLESS
    • david.uribe
      I am using LS-Dyna R11.2.2. I am performing an explicit simulation and then perform the implicit springback step.
      I have successfully used the 2-step approach, in which I call the *INTERFACE_SPRINGBACK_LSDYNA in the first simulation, and then include the generated dynain file in the second simulation. This approach works.
      However, I have tried to combine both approaches using *INTERFACE_SPRINGBACK_SEAMLESS, and while the simulation runs, it will not output the ASCII dynain or lsda binary files. I have tried to include both *INTERFACE_SPRINGBACK_SEAMLESS and *INTERFACE_SPRINGBACK_LSDYNA in the same keyword, but then the implicit simulation does not run at all, though it outputs some dynain file.
      Is there any conflict between using *INTERFACE_SPRINGBACK_SEAMLESS and generating the corresponding dynain file automatically?
    • Nanda Veralla
      Hello David,
      There's nothing explicitly mentioned in the manual regarding dynain generation while using SEAMLESS. You can find more under remarks in the Manual Volume I
      Nanda
      Have a look at our public help documentation: Ansys Help
      For more exciting courses and certifications, check this out: Learning
