TAGGED: 3dmodel, induced-current, Induced-Voltage, induction-coil
September 4, 2023 at 9:13 am
dinushaxdn
SubscriberHi guys, I'm trying to figure out the optimum parameters to induce the highest voltage in a coil. I used a hollow-type polygonal core with 12 sides and another hollow-type polygonal cylinder around it as the coil. Can someone tell me how I can change the diameter of the coil please? Is changing the thickness of the hollow coil sufficient?Â
September 6, 2023 at 9:05 pm
DELI
Ansys EmployeeHi, yes, thickness&size of the coil and/or number of coil turns can change the diameter of the coil.
September 7, 2023 at 1:42 am
dinushaxdn
SubscriberHow does the number of turns change the diameter of the coil? Is there a formula to calculate it?
September 7, 2023 at 1:52 pm
DELI
Ansys Employeenumber of turns is defined in coil terminal when winding excitation is assigned.
- The topic ‘Induced voltage in a coil’ is closed to new replies.
