3D Design
3D Design
Incorrect Dimensions drawingsheet
    • paul pladet
      A customer tried to dimension a part in the drawingsheet, but somehow it displays the incorrect dimension.
      The correct dimension should be 20mm, but somehow in a different view its 27mm. You can also see that 27mm should be the edge of the circle.
      Any ideas why this could happen?
    • Devendra Badgujar
      Hello Paul,
      Are the dimensions on different plane? Can you try changing this option to TRUE:
      Let me know if this helps.
      Devendra
