LS Dyna
LS Dyna
Inconsistency LS-PrePost and manual for ICFD_BOUNDARY_PRESCRIBED_SPTRANSP_CONC
    • k23052087
      Hello everyone,
      I encountered a possible inconsistency when setting the concentration boundary condition for species transport in LS-DYNA.
      The keyword *ICFD_BOUNDARY_PRESCRIBED_SPTRANSP_CONC appears differently in the LS-PrePost keyword interface and in the LS-DYNA manual.
      In LS-PrePost, the keyword is shown as a two-line structure:
      • the first line defines the PID
      • the second line contains the LCID values
      However, in the LS-DYNA manual, the keyword is documented in a single-line format where PID, LCID and CONC fields appear together.
      Because of this difference, I observed the following behaviour:
      1. If I follow the format shown in LS-PrePost, the solver produces an error:
      input conversion error
      forrtl: severe (64) 已上传的图片 (3).png
      and the simulation cannot start.
      1. Even if I instead follow the manual format and remove the second line, the simulation runs but the concentration boundary condition does not seem to be applied. In this case:
      • the inlet concentration remains zero
      • residuals for the scalar transport equation are not computed
      I also noticed a similar mismatch for another keyword related to species transport:
      *ICFD_MODEL_SPECIES_TRANSPORT
      where the format in the LS-PrePost interface does not fully match the manual description.
      Because of this inconsistency I am currently unable to run simulations that require inlet concentration boundary conditions for species transport.
      Could anyone clarify:
      • The correct keyword format  *ICFD_BOUNDARY_PRESCRIBED_SPTRANSP_CONC
      • whether this difference between LS-PrePost and the manual is expected
      • or if this might be a bug?
      My LS-DYNA version: R16 SMP and LS-PrePost version: 4.12.6
      Thank you so so so much for any guidance!
Viewing 0 reply threads
