Ansys Free Student Software
Inconsistency in the results of one of the lessons
    • yarykgv
      Hello everyone, the other day I went through one of the lessons on using Ansys Fluent - /courses/index.php/courses/cfd-in-aero/lessons/commercial-aircraft-propulsion-thrust-from-a-convergent-nozzle/
      I did everything right and got the same result as in the lesson:
        - from lesson
      - my data
      But I decided to check the coefficients from the "Results and Discussion" section using the same formulas and nothing matched:
      • - from lesson
      • - my data calculated in MathCad
      The problem is that I can't understand what I calculated wrong. I assume that I do not correctly understand some physical quantities in the formula.
      Task input -
    • Federico
      R is the air specific constant of R_air = R_universal/M_air = 287 J/kg/K, not the universal gas constant.
      • yarykgv
        Thank you very much. Now everything is correct.
  • The topic ‘Inconsistency in the results of one of the lessons’ is closed to new replies.
